by Thequeenscheese » Thu Sep 21, 2017 7:28 pm
Yes all work fine, the hardest bit (and I still have to fettle this) is getting them to line up and now I know they work I'll need to glue the pcb into the housing so it doesn't move inside when fastened and sealed.
The how to tbh is easy cut most of the perturbing locating plastic away from the inside including the locating screw tube at the back (which is shy the rear of the key will need to be glued or sealed together), file away unnecessary pcb where needed and the white plastic housing making sure not to file into any chips or crucial bits if your careful you may not need to glue the pcb in the housing but I filed a little too much off at one end and it moves now unalighning the buttons but other than that it easy peasy I did it on my knee with rudimentary kit in half darkness.
It still amazes me that there isn't any official ones out there tbh.
2.2 tdci T280
