What did you do to your mk6/7 today?
Re: What did you do to your mk6/7 today?
Postby birdie » Wed Dec 06, 2017 11:04 pm
Not my fault, so insurance can have it
mk7 T350 FWD towing van
birdie
Postby Tango330 » Thu Dec 07, 2017 11:41 am
motorman116 wrote:Washed and dried my Transit, nice and clean for 5 mins
Sent from my SM-A520F using Tapatalk
Looks like you might be digging it out tomorrow Mate :shock:
T330 RWD now sold
Ford Ranger Wildtrack now sold
MI 5 sacked me from my job as an interrogator this morning, didn't like to ask why :?
Tango330
Postby motorman116 » Thu Dec 07, 2017 12:56 pm
:shock: There is nothing wrong with a bit of side way drifting :lol:
2008 3.2 5 pot diesel Ford Transit GLX Lwb, Hr
motorman116
Postby dirtydog » Thu Dec 07, 2017 5:43 pm
Found this in the back of the van earlier
I’m pretty sure there shouldn’t be a puddle there :shock:
dirtydog
Postby andz327 » Thu Dec 07, 2017 5:56 pm
birdie wrote:Not my fault, so insurance can have it
Probably write it off
andz327
Postby loot » Thu Dec 07, 2017 6:01 pm
dirtydog wrote:Found this in the back of the van earlier
That's what all transit owners say :lol: bloody denial!
I find that as soon as you accept it then you can embrace the prospect of weather proofing :-)
That screw tells me that it was owned by a careless trampy builder type before you? :P
If you remove the back light lend and look down you'll see fresh air and mud which is where splashes and stuff get up there, not sure if it can work it's way over to the front of the arch and cause the puddle but it clearly isn't draining out so it might be worth checking the drain holes etc and if not then maybe make 1 but use something to seal it.
(Subliminalmessagingbuyacustomdoitnowitsonlymoneymwahaha)
07 350 170ps
Ids map here
loot
Postby dirtydog » Thu Dec 07, 2017 10:34 pm
That puddle is between the arch and rear light, didn’t have time to take a look this afternoon to see if there’s anywhere obvious that it’s coming from
Can’t afford a custom :(
dirtydog
Postby loot » Thu Dec 07, 2017 11:23 pm
dirtydog wrote:That puddle is between the arch and rear light, didn’t have time to take a look this afternoon to see if there’s anywhere obvious that it’s coming from
https://auctions.hills-motors.co.uk/veh ... rt=0&srch=
:D
07 350 170ps
Ids map here
loot
Postby Punto443 » Thu Dec 07, 2017 11:24 pm
Seized handbrake lever on the rear caliper.
Pulled the caliper off, while working the lever the spring came off. That’s a c*** to get back on
Then the f*** piston came out,
Then it started raining.
Then the bleed nipple was choked up, took it out, cleaned it up, bled the brakes.
Went to top up the fluid and snapped the b*stard key in the bonnet lock!
Bit of sh*t night really, but all sorted now :D
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby loot » Thu Dec 07, 2017 11:32 pm
Punto443 wrote:Seized handbrake lever on the rear caliper.
:shock:
07 350 170ps
Ids map here
loot
Postby Airthies » Fri Dec 08, 2017 1:01 am
That's a bit rough punto.
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Punto443 » Fri Dec 08, 2017 8:04 am
Tell me about it! And I’m feeling sh*t the now with the cold etc, could have done with out it :?
But without the sh*t days, we’d never appreciate the good ones :lol:
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby Airthies » Fri Dec 08, 2017 8:24 am
Punto443 wrote:Tell me about it! And I’m feeling sh*t the now with the cold etc, could have done with out it :?
So philosophical and deep for such a time of morning
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Punto443 » Fri Dec 08, 2017 10:11 am
I’m a shallow puddle, but cast a deep reflection :lol:
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby spoonman » Fri Dec 08, 2017 3:05 pm
Put on some new Matador MPS400 tires on the old van...
Cheers,
Lars
spoonman
