Towing weights
Towing weights
Postby man le-mans » Sat Jan 06, 2018 7:38 pm
My mk7 T350 115BHP fwd has a GTW of 5500kg
The mk8 350 130BHP fwd from what I can see has GTW of 5050kg
This is disappointing has it's a big difference. Is the heavy duty axle a towing axle and will allow me to carry more ie 5500 giving me a different diff
https://www.ford.co.uk/content/dam/guxe ... it_Van.pdf
MK8 L2H2 T350 TREND 68 plate silver 130bhp
Mk7 MWB M/R T350 TREND 2010 SILVER 115BHP
MK7 MWB M/R T350 2009 BLUE 115BHP (crap)
MK6 MWB M/R T280 full electric pack silver 2003 85BHP
Smiley face T reg L/R SWB ex BT
man le-mans
Re: Towing weights
Postby Altransit » Sat Jan 06, 2018 9:21 pm
If towing weight is important, why wouldn't you buy a RWD :?: :?
Re: Towing weights
Postby man le-mans » Sat Jan 06, 2018 9:43 pm
Altransit wrote:If towing weight is important, why wouldn't you buy a RWD :?: :?
Because they are higher and don’t fit under my canopy.
man le-mans
Re: Towing weights
Postby ME » Sun Jan 07, 2018 1:05 am
Gtw's are down to axle ratios, the mk8s have low axle ratios as standard hence the low Gtw's
Mercedes Vimto Premium
ME
Re: Towing weights
Postby man le-mans » Sun Jan 07, 2018 11:30 am
So would the 4.43 standard axle be much different to the uprated axle 4.71 in MPG, and make it rev lots more on motorways
man le-mans
Re: Towing weights
Postby Altransit » Sun Jan 07, 2018 11:38 am
You're looking at a ratio which is under 8% wider, (4.43 x 8%=4.78) so whatever was your speed at 3000rpm, will now be just under 240rpm more (3240rpm) for the same speed. :)
Re: Towing weights
Postby man le-mans » Sun Jan 07, 2018 4:15 pm
Thank you, sounds like half a gear difference if that makes sense
man le-mans
Re: Towing weights
Postby Altransit » Mon Jan 08, 2018 9:09 pm
Interestingly, when I fitted bigger wheels/tyres to my Mk6, (which effectively gave it longer legs by 10%) the overall fuel consumption was no better than "as standard" and in fact was just a tad worse. This was probably due to the gear ratios being a bit high for the engine, and more frequent gear changes required :(
Re: Towing weights
Postby man le-mans » Mon Jan 08, 2018 11:17 pm
I was thinking along them lines, with a bigger diff would make even less MPG. I know a few mates that have the mk8 now and all say the MPG is down compared to the mk7, and to make it even worse with a towing diff.
I don’t tow my track car that much but would like to in the future.
Now confused with what to do.
Only ordered it few weeks ago so can still makes changes I think.
man le-mans
