Warning Light / loss of power ,
Postby bryan1701 » Sat Feb 10, 2018 12:53 pm
Hello
I appreciate this has been covered before but reading all the posts I am still somewhat in the dark so please be patient and as always I am grateful for your advice
Whilst driving on the motorway last December and towing a light trailer I experienced a sudden loss of power and the "coil wire" warning lamp illuminated , I turned off the ignition and restarted and all was ok again , she has continued to do this of and on for the time since , she has also been somewhat reluctant to start , in late december I took a long motorway journey and had no trouble at all , it seemS to happen when I put the engine under load but in too high a gear , I gave her a service and used diesel injection cleaner , and did a EGR valve clean using a spray product , the engine pulls well all the time with no spluttering etc . when starting it take several attempts and there is a amount of smoke as I turn her over , its white smoke , she is not using oil and fuel consumption is as normal .
Transit connect T200 TDCI
2003
91,000 Miles
thanks in advance
Bryan
bryan1701
Re: Warning Light / loss of power ,
Postby liteace » Sat Feb 10, 2018 1:38 pm
Sorry, same answer as always, plug in diag tool and read codes
Please don't send me PM's, i can't access them, when I try I get this:
You are not authorised to send private messages
liteace
Postby paul2012 » Sat Feb 10, 2018 8:09 pm
2003 Connect 90ps TDCI....
Glow plug light flashing & engine going into limp mode under heavy acceleration. Clears when engine has been restarted.
No doubt following DTC's (error codes) will stored.
P0251 Injection Pump Fuel Metering Control
P1211 Injector Control Pressure Higher/Lower Than Desired (engine running)
Common problem effecting 2003-2006 Connects with Delphi fuel systems. :idea:
It will either be injector fault or fuel pump. or in some cases both :!:
Injector leak of test will confirm in injectors are at fault. - If 1 or 2 are faulty, it's best to replace all 4 :idea:
Check diesel filter for swarf - If present, fuel pump has worn out.
Replacement fuel pump & injectors are required.
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby bryan1701 » Sun Feb 11, 2018 2:54 pm
ok , thanks for taking the trouble to reply ,much appreciated , have ordered a code reader so will report back , there was no swarf or any sort of debri in the diesel filter last service
bryan1701
Postby paul2012 » Tue Feb 13, 2018 4:14 pm
bryan1701 wrote:ok , thanks for taking the trouble to reply ,much appreciated , have ordered a code reader so will report back , there was no swarf or any sort of debri in the diesel filter last service
Don't get a generic ODBII code reader/scanner...
2000-2006 Connects are NOT ODBII compliant :!:
paul2012
Postby bryan1701 » Wed Feb 14, 2018 12:51 pm
ok , thank for the advice about the code reader , I looked through the forums and got a f-super 2 done the job
well as you say a common problem, codes I had were
P1211
P2291
P0251
P0251
So looking at a changing the van , it is too much money for a new set of injectors / pump etc going used is not worth it to me , will live with the problem until it fails
will look for a tddi next
thanks again for the advice , much appreciated
bryan1701
Postby g-man » Wed Feb 14, 2018 12:58 pm
has it got an oem fuel filter?.......and it don't cost much to do a leak off test
g-man
Postby bryan1701 » Wed Feb 14, 2018 5:54 pm
Hi G-Man , no its a pattern one , never had a oem in my time with it (got it in 2008 ) did a filter change last december , no swarf to be seen , as she does not owe me anything i'll be looking around for a replacement van .
bryan1701
