ABS Brake bleeding with forscan
Postby Airthies » Wed Feb 14, 2018 9:35 pm
Has anyone successfully bled the ABS system with Forscan?
I've just replaced every brake line on the van so it's a full refill and bleed about to happen.
I'd be usually using IDS but it's in a huff with the VCM so I'm going to try it with forscan and a modified elm327 (after a cup of tea...)
So if it's an unknown it will be known either way later.
Sent from my anu5 using crapatalk
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Re: ABS Brake bleeding with forscan
Postby davyjcb » Wed Feb 14, 2018 9:41 pm
If your using forscan and you have a vcm2 you can use the vcm an elm 327 is not required and you will find all modules with the vcm2 no switching hs/ms can
96 escort 55 van gone
98 smiley mwb semi high gone
01 90/350 mwb semi high roof gone
05 135/350 lwb semi high roof gone
10 85/260 swb low roof leader gone
09 140/350 lwb semi high fwd
11 115/330 mwb semi high roof
davyjcb
Postby Airthies » Wed Feb 14, 2018 10:58 pm
My vcm is not talking to the laptop so resigned to forskin and elm
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Airthies » Wed Feb 14, 2018 10:59 pm
I have used forscan with the vcm11 but it's in a huff after the laptop did a big update the other night
V86+patch
V86.04
X-Prog
C81
Airthies
Postby davyjcb » Thu Feb 15, 2018 12:59 am
The vcm drivers have updated you have to roll it back to the drivers that were currant for 86.04 and that's an uninstall operation
davyjcb
Postby davyjcb » Thu Feb 15, 2018 1:08 am
(if you just do the red tab reset on the vcm when it boots up again without Uninstalling what's on your laptop hard drive it will install the latest version and roll right past the one you want I think that someone in the know could sort it without going about it that way but I don't so that's the way got round it)
davyjcb
Postby Airthies » Thu Feb 15, 2018 3:27 am
Ah there in lies the only flaw in my trusty old com, the reset button does not work
Have done a reinstall and tried the two versions of Bosch drivers but it's not liking it even the Bosch manager can't see it now where it could before.
But anyway forscan and the modified elm327 have doen the job fine.
Nice n simple
A wee drive test tomorrow before work an the Mrs can take it for it's retest!
V86+patch
V86.04
X-Prog
C81
Airthies
Postby ned » Thu Feb 15, 2018 7:23 am
How do you do it with forscan then? N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby Airthies » Thu Feb 15, 2018 1:43 pm
Yep worked a treat even without the pressure bleeder it requests.
I purged the master cylinder first to get the fluid moving to the ABS pump, then just went through the bleed cycle I think 3 times just to be sure (I had 5lt to play with)
It's a doddle if you've got van jacked up on stands and wheels off
Full brake line replacement and have about 500mm of tube left from 2x 25ft(~7m) rolls of tube to do a LWB Mk7.
The main lines from master to AND were the worst getting them round the back of the engine bulkhead.
Fuel filter off, coolant bottle off. Front headlight out. But all in all not a bad job....
V86+patch
V86.04
X-Prog
C81
Airthies
Postby dirtydog » Thu Feb 15, 2018 3:01 pm
I replaced just the split section on my driver side front brakepipe as I looked at replacing from the abs pump and it looked a right pain to get round the back of the engine.
Might replace all the pipes in the summer when I have some time off and I'm not in such a rush to get it back on the road
dirtydog
Postby knobby1 » Wed Feb 21, 2018 7:36 pm
Airthies wrote:Yep worked a treat even without the pressure bleeder it requests.
Fuel filter off, coolant bottle off. Front headlight out. But all in all not a bad job.... Sent from my anu5 using crapatalk
Great work Airthies...good info for the rest of the lads.
Postby Punto443 » Wed Feb 21, 2018 7:54 pm
I’m probably doing mine this weekend, so I’ll give it a bash :D
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
