Are turbo failures on the 2.2 common?
Postby Damien89 » Fri Sep 22, 2017 9:28 pm
Here in malta all minibuses have had there turbo replaced under warranty due to the electronic actuator failing. Are these failures common in the uk?
Damien89
Re: Are turbo failures on the 2.2 common?
Postby loot » Sat Sep 23, 2017 9:58 pm
I haven't read many, I'd propose that the heat and dust in Malta is the likely cause. :-)
Could be way off tho :oops:
07 350 170ps
Ids map here
loot
Postby ME » Sat Sep 23, 2017 10:34 pm
loot wrote:I haven't read many, I'd propose that the heat and dust in Malta is the likely cause. :-)
Sounds like a Ford dealers warranty get out sentence.
Have you thought about a new career as a Ford warranty claims administrator :lol: :lol:
Mercedes Vimto Premium
ME
Postby loot » Sat Sep 23, 2017 10:36 pm
Well i can poo poo most things offered, i get it from my mum :lol:
07 350 170ps
Ids map here
loot
Postby Damien89 » Sun Sep 24, 2017 7:56 am
Its the electronic actuator thats failing not the turbo itself.
Damien89
Postby MK7 user » Sun Sep 24, 2017 10:54 am
ME wrote:Sounds like a Ford dealers warranty get out sentence.
My apologies to the OP for gate crashing his thread....I'd like to ask a Moderator why these tossers with Sprinters are allowed to chime into a Transit forum....they don't have anything positive to add to a thread, their input is intended to ridicule anyone who owns a Ford Transit :!:
No Squire, not just any van....it has to be a Mk7 (VM.1) :D
MK7 user
Location: Grim HQ in the parish of Aston Nr the Great Hall
Postby loot » Sun Sep 24, 2017 1:47 pm
Yes i know, the turbo can get white hot and as long as it isn't rusting to death or starved of oil then it should be fine.
The actuator is a little electronics box that has a motor and gears and a circuit board inside a plastic box which is located worryingly close to the extremely hot turbo, compounded by the fact that the weather in Malta is rather hot in summer and that (correct me if I'm wrong) but the makeup of Malta is largely volcanic rock type material and not much greenery and arid (hottest time of year anyway)
Which is why i supposed the failure rate you suggested could be so.
Uk egr valves tend to fail quite commonly and they are a similar setup in relation to the turbo actuator on the vnt.
Bloody Ford. :lol:
(The above assumes that the failure rate you stated is actually high and i have no corroborating into to go on)
07 350 170ps
Ids map here
loot
Postby RECKLESS ROAD » Mon Sep 25, 2017 11:00 pm
my turbo failed on my mk8 2.2 at 23,000 miles, they said it just jammed/seized
RECKLESS ROAD
Postby msmyth » Wed May 02, 2018 10:11 am
I have had 2 Mk 8 vans, both had turbo failures before 20,000 miles and under warranty.
The last one packed in on the M6, blocking the particle filter so the engine died totally.
When recovered to the local dealer he told me he had THREE other Mk 8s in for the same issue!
So, yes, these failures do seem to be common!
msmyth
Postby sigtravel » Wed May 02, 2018 4:50 pm
My 2.2 minibus is having turbo issues - I'm 4 months out of warranty though.
at 1750 revs when under medium load it stutters then kicks into limp mode. Just trying to find a couple of quiet days where I can afford to take it out and have a look.
sigtravel
Postby man le-mans » Thu May 03, 2018 4:30 pm
sigtravel wrote:My 2.2 minibus is having turbo issues - I'm 4 months out of warranty though.
4 months out of warranty isn’t good have you asked for Gesture of good will to help with the cost.
Does it have full dealer service history
MK8 L2H2 T350 TREND 68 plate silver 130bhp
Mk7 MWB M/R T350 TREND 2010 SILVER 115BHP
MK7 MWB M/R T350 2009 BLUE 115BHP (crap)
MK6 MWB M/R T280 full electric pack silver 2003 85BHP
Smiley face T reg L/R SWB ex BT
man le-mans
Postby Damien89 » Sat May 05, 2018 11:25 am
Most probably its the actuator starting to fail.
Damien89
Postby ake » Sun May 06, 2018 5:11 pm
I think you need to calm down a bit.
Postby sigtravel » Thu May 10, 2018 5:17 pm
Yeah full history with Ford, will have to get it booked in and see what they say.
sigtravel
