Breaking my Transit Mk5
Re: Breaking my Transit Mk5
Postby Choppergeoff » Wed Apr 18, 2018 10:02 am
OK Folks.
The engine, trans and associated parts are now sold.
STILL AVAILABLE ........Everything else.
5 stud axle, ratio unknown. fully rebuilt with new bearings ,seals and slave cylinders, Anti lock brake sensors........... £75
Nearside side loading door. solid ,no window, in White.............................................................................. £45
Offside side loading door window ,no glass, in White............................................................................. £50
2 x Non opening , clear side window glass, with rubbers............................................................................ £25 each
2 x front 5 stud hubs , Land Rover PCD ...............................................................................(
2 x Adapters, Transit to Land Rover PCD ..............................................................................)................ £150
4 x Alloy Land Rover 5 spoke 6 x 16 wheels and (knackered ) Pirelli scorpion tyres...........................(
Tourneo Hatchback..Bare door,in good condition. light repair to top of door ,not structural,with glass..................... £60
Plus many small items, please ask for availability.
ALL REASONABLE OFFERS ACCEPTED
Thanks Geoff
I don't do Standard and I don't do Normal...whatever that is
[url]Past vans [/url]1966 Mk 1 V6 3.0ltr Camper. 1982 Mk 2
9 or 10 Mk 3/4/5's
current ...Customised SHR LWB twin SLD Door Chopped roof Turbo D
Choppergeoff
Postby Choppergeoff » Mon Apr 30, 2018 12:18 pm
......QUICK UPDATE...
The entire front end , from the doors forwards has now been sold.
There are many spares, including bonnets ,grilles gearbox ,engine parts ,lights indicators both amber and clear,
I'll list other parts separately .
9 or 10 Mk 3/4/5's
Choppergeoff
Postby Choppergeoff » Fri May 11, 2018 2:34 pm
Pocketrocket wrote:What's the condition of the tailgate and how much?
Hi.
I'm selling 2 as a job lot on ebay at the moment. i good tailgate ,the other has the gas struts,handle and lock etc.
eBay item number:132609849088
Have a look and make me an offer. I'll give a discount to a forum member.
also, I forgot to include the rear tinted window in the ad, which is of course ,included.
Thanks Geoff
9 or 10 Mk 3/4/5's
Choppergeoff
Postby Choppergeoff » Sat May 12, 2018 10:00 am
OK Folks.
5 stud axle, ratio unknown. fully rebuilt with new bearings ,seals and slave cylinders, Anti lock brake sensors.......... £75
Offside side loading door with non-opening window supplied, but not fitted ,, in White..................................... £50
Mirrors .non electric...both sides available ............................................................................................£15 each
2 sliding doors N/s & O/s with opening half windows fitted .good condition ,but require finishing and painting. .......£35 each
2 x Rear doors. reasonable condition, needs paint....................................................................................£40
Tourneo Hatchback..see .eBay item number:132609849088
Good bonnet ,BT grey. good condition. .................................................................................................£25
Customised bonnet with steel power bulge / intake .................................................................................£45
Tow bar ,with electric hook up socket and mounting plates. re-painted..........................................................£25
Thanks Geoff
9 or 10 Mk 3/4/5's
Choppergeoff
Postby enjoythistripp » Mon Jun 04, 2018 8:35 pm
Did you sell the tow bar? if not where are you?
You can take a man out of a transit but you cant take the transit out of the man
T350 2.4 TDCi Xlwb Luton 115ps 2007
enjoythistripp
Postby twin wheel camper » Tue Jun 05, 2018 8:59 pm
Just incase the towbar your after is for your Luton extended frame it is different to Van or standard chassis cab, as I said it maybe for your other mk5 van but the extended frame it fitted with a odd ball towbar apparently :(
twin wheel camper
Postby Presonus4 » Thu Jun 07, 2018 1:52 am
Do you still have anything from the Bosch conversion? Particularly the accelerator pedal?
Sent from my Redmi Note 5A using Tapatalk
Presonus4
Postby Catjenkins » Mon Jun 11, 2018 3:52 pm
Have you still got n/s side door with opening window
Catjenkins
Postby Choppergeoff » Fri Jun 15, 2018 3:45 pm
enjoythistripp wrote:Did you sell the tow bar? if not where are you?
Hi. Sorry for the delay. I've been abroad until recently.
Yes I still have the tow bar and fitting brackets.
I'm in Hyde ,Cheshire. 2 mins from J3 on the M67.
PM me for the address and postcode if you are still interested
Thanks Geoff
9 or 10 Mk 3/4/5's
Choppergeoff
Postby Choppergeoff » Fri Jun 15, 2018 3:50 pm
Catjenkins wrote:Have you still got n/s side door with opening window
Hi Cat.
I've got a good side door with no window, so you could find an opening window and have it fitted.
Would that be any good to you?
Thanks Geoff
9 or 10 Mk 3/4/5's
Choppergeoff
