How many Mk6 petrol/lpg are out there.
Re: How many Mk6 petrol/lpg are out there.
Postby Ian williams » Sat Jan 27, 2018 10:04 pm
I have a 2007 transit 2.2 lpg on a mazda engine are they any good on gas.what lpg system is on it
Ian
Sent from my SM-G900F using Tapatalk
Ian williams
Postby madmart132 » Tue Jan 30, 2018 1:59 am
Hi Ian most of us on here have MK6 vans not really to sure on MK7 , ford did not make a factory lpg version of the mk7 so look under the bonnet for a small black box ( the lpg ecu ) with wires leading to the gas injectors, it should have the name of the software manufacturer written on it .
madmart132
Postby Oldfossil1 » Tue Jan 30, 2018 2:26 am
Have owned my van for 5 months now.
Had a surprise a recently when spotting a similar T300 this particular van was only running single fuel and not both.
Oldfossil1
Postby gasman » Sun Feb 25, 2018 10:00 pm
Forum name ................. Model..................... LPG working Y/N
1/ mealic ...................swb low roof 04..................Yes 111,000 factory fit
2/ Madmart132.............Jumbo 03 lpg.....................Yes ( But not Factory fit !!) 250,000 miles now 25 mpg Pet 17-22.5 mpg gas
3/ User774................. Swb low roof 54..................Yes 200,000 miles, london traffic so no idea of mpg. Lpg used in traffic, petrol used at speed.
4/rogerw....................Swb low roof 03 ..................None
5/ Rowdey-.................MWB/MR. 2003................... 205,000. Factory LPG with extra 90l tank.
6/ rikki19...................MWB mid roof 2001 ..............2.3 petrol 270klms....no lpg
7/ Chimplad28.............Mwb high roof, 51.................Yes,119000, Aftermarket 2.3 Petrol, Roughly 20mpg on gas
8/ Andycaravan............LWB High roof 2002...............Yes ( with rpobs ) 195k factory 18 - 20 mpg fitted extra 145 ltr tank get 750+ miles per fill
9/ injected.................MWB pick up 02....................yes, was Vialle now BRC
10/ injected................MWB pick up 02................... Yes, was Vialle, now BRC
11/ injected................MWB pick up 05....................yes, factory LPG
12/ zobby...................MWB high Roof 03.................55,500 miles, factory LPG NOT-WORKING, Petrol Perfect!!
13/ Captain Hook..........SWB Lowroof 2004.................Factory LPG
14/ Captain Hook..........SWB Lowroof 2005.................Factory LPG (Project!)
15/ Weeds...................SWB low roof 01...................No LPG 250K/Kms
16/ VGM.....................SWB Low Roof 53..................2.3 LPG, 145k LPG Not Working Fine On Petrol :?
17/ moschops...............LWB Semi-Hi roof................Petrol ok, LPG only works when engine v.hot
18/Kevin mwb Hi roof BRC after market works well about 22 mpg on gas.S
19/mad dog 03 2.3 lpg....SWB Low Roof 03 UK..............2.3 LPG 216k LPG SEEMS TO BE TEMPERMENTAL OR GAUGES STICKIN AGAIN WELDED UP FOR MOT PRETTY SOLID N FLIES LIKE A ROCKET 6 SEATS :D :lol: :lol: :lol: :twisted: :twisted:
20/Gasman.................SWB Low Roof 2004.................2.3 ,Factory LPG,99k,lpg works
gasman
Postby Oldfossil1 » Sun Feb 25, 2018 10:07 pm
Ahem.
Old Fossil T300 LPG working Y White swb medium roof 52 120000 2.3 factory fit
Oldfossil1
Postby flashbaztard » Tue Mar 13, 2018 10:23 pm
2003 swb running gas 165k
Sometimes seems to misfire,
(I had a convoy with factory fitted lpg and there was a hidden switch so you could turn gas off do transits have these?)
flashbaztard
Postby moto » Sun Apr 08, 2018 7:15 pm
If it is factory there should be a switch on the dash with a bottle on it. That will be the LPG one. If your misfire is slight, have a look at the coil packs, and see if the connector port on the coil pack is damaged from heavy handling - they appear quite fragile. I used resin to reinforce the connection so it is a little more bulletproof. Check that before getting the wallet out!
Whilst here - anyone have the OBD wiring diagram? Not for the ports, but for where it goes from there (the bus live on main loometc) - this one seems to have been fiddled with! lol!
moto
Postby CROSSFIREROB » Wed Apr 25, 2018 10:08 pm
Today I bought a new RPM filter i didn't need one ,but I heard they were to stop making them , I didn't believe the guy so I had a ring around and couldn't get one , so I would recommend getting a spare while you still can ,seeing as they have a habit of failing .Just saying :D
Rockin and a rollin all day long !
CROSSFIREROB
Postby madmart132 » Fri Apr 27, 2018 11:17 pm
Hi Bob I am just going to replace the complete front end system on my van,i can then do the diagnostics myself as nobody seems able to work on the factory systems .
By the way now you have replaced the cat how fast is your van?
madmart132
Postby simon01775 » Wed May 02, 2018 10:46 pm
21/simon01775.............SWB Low Roof 2002................2.3 LPG 135k and LPG works but having issues with cooling fan not kicking in!!
simon01775
Postby trans-it-mad » Wed May 23, 2018 11:12 pm
22/ trans-it-mad...........LWB High Roof 2002.................YES factory, 87K it like to switch back to petrol, so I need to stop and restart
trans-it-mad
Postby johnniieee » Sat Jun 09, 2018 1:51 pm
Form name Model Mk6 LPG working
johnniieee swb low roof 06 Yes[/quote]
johnniieee
Postby johnniieee » Sat Jun 09, 2018 8:41 pm
johnniieee wrote:Form name Model Mk6 factory fitted LPG LPG working
[/quote]
johnniieee
Postby trans-it-mad » Mon Jun 25, 2018 4:22 pm
so with all this transit LPG, can someone recommend me a good mechanic in london area, preferably north? I had dirty LPG that f**k up my engine and I need attention because all my do, make it better but not sort the problem. Now my engine shake like hell and the engine light come up time to time, sluggish engine. please help!
MK6 LWB RWD BI-FUEL broom broom :lol:
trans-it-mad
Postby madmart132 » Wed Jun 27, 2018 9:49 pm
Hi,we need a bit more information about the van ,year lpg system etc also try the lpg forum
madmart132
Users browsing this forum: Google [Bot], Majestic-12 [Bot], md89
