Vibration on the steering wheel and dash
Postby VanPlan » Wed Jun 06, 2018 3:18 pm
Recently my vans dash and steering wheel are vibrating even in neutral, I know you get some coming through but it's really peeing me off now.
When I rev to a certain point they go away.
Any obvious signs like the mountings?
Please help as I'm in the van 10hours a day.
Man with a plan thats got a smiley Ice cream van!
Currently working on the exterior of the van :D
Ford Transit MK5 2.5DI (Smiley) - Ice cream van conversion.
VanPlan
Re: Vibration on the steering wheel and dash
Postby cherniy_chack » Wed Jun 06, 2018 4:55 pm
Bent discs on the front wheels, damage to the tires of the front wheels.
Or does the steering wheel vibrate on a standing car when the engine is running?
cherniy_chack
Postby VanPlan » Wed Jun 06, 2018 5:50 pm
It's only on tickler, tyres and wheels are solid
VanPlan
Postby gotgcoalman » Wed Jun 06, 2018 6:24 pm
On tickover?
Only mounts are.........
2 in the engine bay and the gearbox one.
Too bloody quiet :shock:
gotgcoalman
Postby cherniy_chack » Wed Jun 06, 2018 7:12 pm
On idle motor?
cherniy_chack
Postby gotgcoalman » Wed Jun 06, 2018 10:40 pm
could be a duff injector causing rough idle :?:
gotgcoalman
Postby VanPlan » Wed Jun 06, 2018 11:15 pm
You might be onto something as one of my injectors is losing diesel over the top too. Mounts are ok.
VanPlan
Postby VanPlan » Wed Jun 20, 2018 6:21 pm
Had the injectors checked and mounts checked everything is ok.
I've driven other transits but this ones vibrations are unbearable.
Any other ideas chaps
R
VanPlan
Postby gotgcoalman » Wed Jun 20, 2018 6:58 pm
Try raising the tickover screw on the pump (or via the cable adjuster)
gotgcoalman
Postby VanPlan » Wed Jun 20, 2018 9:10 pm
Tick over screw?
I've sped up the engine via the adjuster the vibrations go down but the engine runs too fast on tick over.
VanPlan
Postby davetheshrew » Fri Jun 22, 2018 10:46 am
get new injector seals, bleed off all the injectors while engine is running (crack the bolt open until fuel pisses out then close it up) , also put about 2 bottles of redex diesel injector cleaner in half a tank, should clean the system up a bit. If just one injector is firing badly the engine feels like its going to leave the bay.
Drab green Transit 190 L High top minibus
turbo conversion with toyosports intercooler
davetheshrew
Users browsing this forum: meerkatmag
