Getaway van it is not!
Postby 13S » Thu Jun 21, 2018 6:40 pm
Hi all
Here we go!
The van (in signature) has been acting up when trying to start over the last few days.when trying to start there is nothing apart from ‘Engine malfunction’and all dash lights and dial drop out party and the glow plug relay clicking like mad, now this will happen every time you try to start it after waiting 30 second for clicking to stop each time but if you wait 5 mins or so when radio display goes out and you here that shut down noise it will start perfectly and run fine.
This morning tho it done the bad start after been left all night.
No codes on crappy reader.
Rear battery newish
Front battery original (but does not struggle with half turn start)
So the van does work but not as a getaway van.
Any help appreciated
Paul
MK7 2.4 140 330 RWD SWB LR GLX DEC 2007 Remapped by Vantuner
13S
Re: Getaway van it is not!
Postby Punto443 » Thu Jun 21, 2018 6:42 pm
Does sound like failing front battery
But get the codes read
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby 13S » Thu Jun 21, 2018 6:53 pm
Punto443 wrote:Does sound like failing front battery
Thanks for that
Worth a punt on battery as it ten years old !
Will get codes read and let you know
13S
Postby Mad Husky » Thu Jun 21, 2018 8:42 pm
Mine sounds like that when the battery is flat usually when i leave it stand for weeks and keep going in and out of it.
Mad Husky
Postby loot » Thu Jun 21, 2018 8:54 pm
Bin the front battery, get a matched 1 for the back 1 if suitable or get 2 bosch s4 110A beasts. :-)
07 350 170ps
Ids map here
loot
Postby 13S » Fri Jun 22, 2018 6:52 am
Sorry, Got batteries mixed up
Front one about year old.
Rear one original
Any thoughts
13S
Postby 13S » Fri Jun 22, 2018 8:15 am
Earth connection for battery’s next to seat gaily rusty but tight , what’s best wat to sort?
13S
Postby 13S » Fri Jun 22, 2018 6:53 pm
Problem to these symptoms solved with the renewal of the rear (starter) of the twin battery set up.
Thanks ladies and gentlemen for pointing me in the right direction .
The van is back as a getaway van, happy days!
13S
