sspeeedy wrote:Hi guys. Well i changed the glow plugs. When i was removing the small nut which holds the electric connector on 3 of them snaped the rod. luckily 1 of them had bn broken a while cos it was rusty when i pulled it out. The other 2 just came out and i was able to remove the main part from the head. The last plu at the back snaped off so now i have the rest of the plug still in the engine so for the moment ive left it until i can work out how to remove it. i did think of using a stud remover as this will fit inside the main shaft of the glow plug otherwise i think the only other way is to remove the head.
Steve
