HIYA I HAVE JUST BOUGHT A TRANSIT 100 2.5 DIESEL ON A P REG PLATE AND IT HAS ONE PROBLEM THAT WHEN ITS LEFT OVER NIGHT OR A GOOD FEW HOURS IT TAKES THE ENGINE ABOUT 20 TO 30 SECOUNDS TO FIRE UP ITS HAD A PUMP ON IT OIL AND FILTER CHANGE BUT I CANT SEE WHAT THIS PROBLEM COULD BE PLEASE HELP THANKS .DAVE
Check on the injectors to see which one the leak off pipe comes from. There was a mod to move this so that the fuel didn't flow back and cause difficulty in starting.
Small cotton braided rubber pipe that comes off the side of the injectors. It links all of them together and then disappears down the back of the engine, it will either do this from the front or the back injector.
did what you said extended the pipe from the fuel tank and pushed it on the injector bit where the cap was and then put the cap on the rear injector thing
