White smoke, no power!
Postby Robin1 » Tue Jan 15, 2008 12:46 pm
Hi there, I have a transit with a few problems :!:
its a 2002 2.0L TDCi,
the van is very hard to start, once started with a bit of help, it bletches out white smoke and has a servere lack of power!
First i checked the timing and pinned the pump which checked out fine.
Then i scanned the transit and it came up with 2 fault codes
P0149 Fuel timing error
P1564 Fuel injection pump - reduced fuel mode request
I am also thinking it could be something to do with the EGR valve but not sure if that would have such great effect on the running!
Can anyone help :?: thanks
Robin1
Re: White smoke, no power!
Postby MrMPuk » Tue Jan 15, 2008 1:35 pm
You wont have pinned the pump if it's a TDCi as you say.
Postby Robin1 » Tue Jan 15, 2008 2:23 pm
I use autodata and for the FIFA engine code which is the TDCi, it is lined up with a 6 mm drill bit as a pin, one in each camshaft pulley and one in the injection pulley, do you think it is a different engine :?: thanks
Robin1
Postby MrMPuk » Tue Jan 15, 2008 2:31 pm
If you send me your reg or chassis number I can check if you have a TDCi.
Postby ianagill » Tue Jan 15, 2008 5:46 pm
try the injectors.
ianagill
Postby MrMPuk » Tue Jan 15, 2008 6:05 pm
ianagill wrote:try the injectors.
That's helpful. Try what with them?
Postby coconut » Tue Jan 15, 2008 11:34 pm
Not possible to have those fault codes on a Tdci :!:
coconut
Ford Technician
Postby AndyG » Tue Jan 15, 2008 11:40 pm
I bet it's a TDDi :!: :lol:
Postby Robin1 » Wed Jan 16, 2008 9:59 am
The reg is SA02XAE chassis WFOVXX
also an engine code on the chassis plate ABFA which is the 2.0D di
has a tubro so maybe a TDdi :?:
Robin1
Postby MrMPuk » Wed Jan 16, 2008 10:44 am
Yep, it's a 100PS which is a TDDi not TDCi.
Postby Robin1 » Wed Jan 16, 2008 12:52 pm
does anyone have any ideas :?: thanks
Robin1
Postby ianagill » Wed Jan 16, 2008 9:29 pm
try change the injectors or get them tested i had the same symptons on mine and the injectors needed changing.i changed them and it was ok.
ianagill
Postby coconut » Wed Jan 16, 2008 10:28 pm
I would think its more fuel pump over fuelling, seen this on lots of front wheel drives, but its still worth getting the injectors tested as well :wink:
coconut
Ford Technician
Postby billtee » Tue Jan 29, 2008 12:06 am
Forgive my ignorance but i always found white smoke was headgasket / is it losing any water ? :idea:
billtee
Postby Guy88 » Tue Jan 29, 2008 4:30 pm
white smoke is unburnt diesel. steam would be H/G
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
