2.5 Di Turbo - Wont turn over * updated * ITS FIXED !!!!!!!
Re: 2.5 Di Turbo - Wont turn over
Postby AndyG » Tue Feb 26, 2008 10:12 pm
Ok :!:
So the Pats light simply stops it's "I am immobilised" blink and simply goes out with no "3 seconds on" when ignition is turned on :?: Yes :?:
Now, if you leave the ignition on for at least a minute, does the PATS light put out a blinking code :?: (pun intended :lol: )
Postby Plug_ » Tue Feb 26, 2008 10:31 pm
Andyg wrote:Ok :!:
Just checked and.... nope , just goes out and stays out :(
Plug_
Postby AndyG » Tue Feb 26, 2008 10:34 pm
Either lack of supply from ign. (blown fuse) or faulty PATS unit :!: :(
Have you checked all the fuses :?: including the ones next to the battery :?:
Postby Plug_ » Tue Feb 26, 2008 10:37 pm
Andyg wrote:Either lack of supply from ign. (blown fuse) or faulty PATS unit :!: :(
Yep checked all fuess and fuseable links by battery...... all ok
So should I just book it into the ford dealer and pay the ransom or is there another way ??
Plug_
Postby AndyG » Tue Feb 26, 2008 10:44 pm
:idea: Disconnect the battery and unplug the PATS unit completely over night and try it again the next day :!:
You know what these computers are like :!: :lol:
Postby Guy88 » Wed Feb 27, 2008 12:01 am
is the PATS on the TD a different system to the non turbo then :shock:
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Plug_ » Wed Feb 27, 2008 12:38 pm
Well.... I've booked it into the local ford dealer....
Monday the friggin 10th March :shock:
And they wont let me have it recovered there till the friday beforehand :evil: no room apparently
The bloody drag race season starts at easter, so its gonna be touch and go :cry:
Plug_
Postby Plug_ » Sat Mar 01, 2008 8:56 am
Bit of an update.....
Put a new battery on it yesterday (just in case) .... no different.
Ordered a replacement pats module (which arrives today) I'll plug that in and see if I get a flash code or summat :|
I'll keep you posted :wink:
Plug_
Postby Plug_ » Sat Mar 01, 2008 4:20 pm
Ok fitted the new pats module (120 quid later :? )
I now get a flash code .... 3 1
Cant find it in the ford manual though .... anybody know what it means :?:
Cheers :wink:
Plug_
Re: 2.5 Di Turbo - Wont turn over * updated * fault code 31
Postby AndyG » Sun Mar 02, 2008 1:35 am
8)
That does tell us that the PATS was indeed faulty :!:
Problem now is, it'll need programming up, so that the codes match :!: :(
Hence the code 3 1 = Code transmission error between ECU and PATS module :!: :roll:
Cables on OK :?:
:idea: Perhaps a mobile Auto locksmith can sort it :idea:
Postby Guy88 » Sun Mar 02, 2008 11:17 am
Needs the ECU programmed to the PATS and possibly the keys programmed.
Could be a main dealer job :shock:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Plug_ » Sun Mar 02, 2008 11:33 am
Ok another update....had the local auto locksmith round yesterday...
He tried to program with his machine but no luck :cry: looked like he was using a "T Code" unit (maybe ?? )
Hes gonna borrow the gear from the local main dealer and pop back monday or tuesday....
fingers crossed :!:
Plug_
Postby Plug_ » Fri Mar 14, 2008 8:39 am
Another update....my van is now with the local main dealer.....they cant program it either and are telling me it needs a new PCM / ECU :cry:
Price of the PCM aint too bad.... 205 quid....but obviously its on fecking back order :cry:
Thinking about sending the PCM to get it repairered....can anyone recomend where I should send it ?
Cheers :|
Plug_
Re: 2.5 Di Turbo - Wont turn over * updated * ITS FIXED !!!!
Postby Plug_ » Sun Mar 30, 2008 10:40 pm
Another update.....
ITS FIXED !!!!!
No thanks to the useless main dealer....but thanks in part to this forum 8)
In the end I sent the ECU to http://www.bluestreak.co.uk/ and for 50 quid plus carriage they "decoded" the ecu and removed the PATS
They turned it round in 72 hours and were totally professional.... top service 8)
Had to disconnect the pats unit and bypass the start inhibitor relay and she fired right up 8)
Plug_
Re: 2.5 Di Turbo - Wont turn over * updated * ITS FIXED !!!!!!!
Postby bazw » Mon Mar 31, 2008 9:37 am
can i come to the party then , guess you ARE having one to celebrate :D :D :D
congrats on a job well done :wink:
350L Series 56 plate
2.4 duratorq 115 ps
A.R. 4.27
bazw
Users browsing this forum: mawman99
