Andyg wrote:Ok
So the Pats light simply stops it's "I am immobilised" blink and simply goes out with no "3 seconds on" when ignition is turned on Yes
Now, if you leave the ignition on for at least a minute, does the PATS light put out a blinking code (pun intended )
Andyg wrote:Either lack of supply from ign. (blown fuse) or faulty PATS unit
Have you checked all the fuses including the ones next to the battery
