EGR valve 2.4 duratorq defender
Postby Verdone » Wed Jun 11, 2008 8:47 pm
Hi all,
I have a small question, i own the new defender with the ford engine ofcourse which comes out of a ford transit van :wink:
I have now 23.000km on it and i had a rumbling noise when idling or not driving fast :lol:
So i blanked of the egr but now the engine management light has come on? Is this normal when u blank it and how can i resolve it?
oh and blanking it off resolved my issue so it actually worked except for the small problem above :|
Thx Verdone
Verdone
Re: EGR valve 2.4 duratorq defender
Postby MrMPuk » Wed Jun 11, 2008 8:49 pm
Welcome
Postby Verdone » Wed Jun 11, 2008 8:52 pm
thank u :wink:
Verdone
Postby MrMPuk » Wed Jun 11, 2008 8:53 pm
Is this not still under warranty?
Postby Verdone » Wed Jun 11, 2008 9:10 pm
yes but thats not the problem at hand now :lol:
I dont like the egr, maney problems with it and i use my defender what it is built for so one item less to worry bout is good :wink:
Greetings Verdone
Verdone
Postby MrMPuk » Wed Jun 11, 2008 9:14 pm
Well what you have done is meant to bring on the fault light.
Postby Verdone » Wed Jun 11, 2008 9:22 pm
There are reports of people who did exactly the same as me without the engine management light :?:
Can i shut it off permantly for the egr fault, not for any other faults that may come on :oops:
Greetings Verdone
Verdone
Postby Guy88 » Wed Jun 11, 2008 9:50 pm
you cant blank the EGR on the TDCi, it uses the airflow meter to measure the ammount of exhaust gas being used, and blocking it as you have found out puts the engine light on
Best bet.......stick a 300tdi in there
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby lostpaul67 » Wed Jun 11, 2008 10:02 pm
Or get it looked at under warranty because if anything else go's wrong and the dealer notices what you've done you'll be stuffed :shock:
T260/130ps Glx
My Mk7 Ford Transit161k miles
lostpaul67
GLX Posse - Founder member
Postby Gurj51ngh » Wed Jun 11, 2008 10:05 pm
lostpaul67 wrote:Or get it looked at under warranty because if anything else go's wrong and the dealer notices what you've done you'll be stuffed :shock:
yep damm right!!
Gurj51ngh
Forums Loudest Van!
Postby Verdone » Wed Jun 11, 2008 10:40 pm
True its not great to do this under warranty, but in sense by blocking it off i cant damage the engine right :idea: :?:
But if other problems not related to the egr arrive i will put the normal gasket in, only a 30 minute job if all goes well :wink:
Greetings Verdone
Verdone
Postby executivetravel » Sun Jun 15, 2008 5:12 pm
having a tdci mondeo (tdci 2.0 130 6 speed) these problems are quite common
if youve blanked off the EGR and it has a sensor on the EGR you need to drill a 5mm hole in the blanking plate
this allows sufficient air to pass to fool the ecu, but doesnt allow the EGR to open.
ive run my mondeo with the EGR defeated (no sensor version) with no problem, and no smoke...
the EGR on the mondeo (cant speak for the transit cos ive not looked yet) simply allows used exhaust gases into the boosted inlet airway on full throttle, removing the small vacuum pipe to it defeats the valve working at all, but plug the pipe too.
executivetravel
Postby martynx » Sun Jun 15, 2008 5:36 pm
The 5mm hole is a good idea, & i have heard from a ford lady that it works well, but better still ask a company called Allisport for advice , they make an EGR defeating device specifically for the TD4 2.4 Defender 90 that you have, it looks like a trumpet which installs at the end of the EGR outlet, rather than a "gasket with no hole " that you probably have fitted so may address your issues. As to whether all egr blanking plates needs a hole in, it varies between vehicles, it may work OK but may not , try it & see...
PS - i dont blame you for wanting to avoid the "warranty", my customer in Essex that has had his TD4 Defender 90 remapped has had the same rubbish , time wasting , "warranty support" that many ford van owners on here have experienced.
for egr/dpf deletes, power tuning, updates,cloning,speed limiter removal,cruise control, euro 3/4/5/6 limiters & key's !
martynx
Postby Guy88 » Sun Jun 15, 2008 6:01 pm
im glad i got a tddi now, mines blanked completly and stopped the puff of black smoke i had after the remap :wink:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Users browsing this forum: Yalding Taxis
