Handbrake adjustment
Postby IB » Wed Jul 30, 2008 10:54 pm
On a 94 transit how do you adjust the handbrake, is it the threaded screw in the linkage underneath ( which is seized) or is there another adjuster elsewhere?
IB
IB
Re: Handbrake adjustment
Postby rover » Wed Jul 30, 2008 11:25 pm
Adjust the back brakes and you will almost certainly find the handbrake is more than acceptable :wink:
Rover.
rover
Postby supertacky » Fri Aug 01, 2008 8:40 pm
The adjuster is the long barrel nut with the two lock nuts either side It sits just infront of the horse shoe. Watch out the rear one is left hand thread! I've seen these stripped before. They are prone to being seized but there are small holes in either side of the barrel nut to lube up before any real force is applied. Heat helps too
supertacky
Postby MrMPuk » Fri Aug 01, 2008 8:42 pm
supertacky wrote:The adjuster is the long barrel nut with the two lock nuts either side It sits just infront of the horse shoe. Watch out the rear one is left hand thread! I've seen these stripped before. They are prone to being seized but there are small holes in either side of the barrel nut to lube up before any real force is applied. Heat helps too
The adjustment is actually on the shoes.
Postby V184 » Fri Aug 01, 2008 9:36 pm
So what is the long barrel nut with the two lock nuts either side for ?
V184
Postby MrMPuk » Fri Aug 01, 2008 9:56 pm
V184 wrote:So what is the long barrel nut with the two lock nuts either side for ?
Adjusting the cable, the brakes them selves are adjusted on the brake adjusters.
Postby V184 » Fri Aug 01, 2008 10:03 pm
What the handbrake cable ?
V184
Postby MrMPuk » Fri Aug 01, 2008 10:04 pm
You've lost me.
Postby V184 » Fri Aug 01, 2008 10:14 pm
Sorry i thought the long barrel nut was to adjust the handbrake, i always de adjust it fully then pump the footbrake so the auto adjusters are set then turn the long barrel nut clockwise to achieve handbrake adjustment is this correct ?
V184
Postby MrMPuk » Fri Aug 01, 2008 10:16 pm
V184 wrote:Sorry i thought the long barrel nut was to adjust the handbrake, i always de adjust it fully then pump the footbrake so the auto adjusters are set then turn the long barrel nut clockwise to achieve handbrake adjustment is this correct ?
That is the procedure, but when you are tightening the cable you aren't really adjusting the hand brake you are achieving the correct adjust of the cable once the brakes are adjusted correctly.
Postby V184 » Fri Aug 01, 2008 10:32 pm
So should IB leave the long barrel nut seized ? what if he takes the brake drums off & finds the handbrake arms not sitting correctly then he cant manually adjust the shoes, in his position i would remove the handbrake adjusting rod by knocking the 2 clevis pins out (correct descripition?) place in a vice and free off or replace if neccessary, while its off pump foot brake to achieve correct adjustment of brakes refit rod and adjust for desired handbrake adjustment.
V184
Postby rover » Fri Aug 01, 2008 11:07 pm
The problem 99.9% of the time is that the shoes dont adjust properly, AND people rarely clean/adjust them anyway, so one day joe bloggs thinks his handbrake comes a bit high and decides to adjust the cable taughtness, thinks he's fixed the problem...and really all its done is sent the shoes out of adjustment! The only time the handbrake cable adjuster should be used is when replacing the cable! after which it should never need touching.
Rover.
rover
Postby IB » Sun Aug 10, 2008 6:07 pm
Thanks for the replys and advice, will do the adjustment at the rear drums.
IB
IB
Postby dickie_mint » Tue Jun 18, 2013 8:07 pm
Hi all, im new to Transit ownership so need a little help. Can someone tell me the correct name for the threaded bar that adjusts the handbrake? ive just snaped mine and need a replacement asap!! Thanks in advance Rich
dickie_mint
Postby trannyfreak » Thu Apr 21, 2016 1:48 pm
How do I adjust them when the drum is on I can't figure it out its a mk5 smiley many thanks
trannyfreak
