top end noise??
top end noise??
Postby transit virgin » Thu Sep 04, 2008 2:08 pm
I've got a high pitch taping/pinking noise coming from the top of the engine, it increases and decreases with the revs. someone has told me that it's an injector? but i just thought I'd see if anyone knows if this is a common problem? it's a 51 350 lwb if that helps?
Oh yes, it's worse in the morning!!!
thanks in advance,
Anthony.
transit virgin
Re: top end noise??
Postby Frag » Thu Sep 04, 2008 2:31 pm
Could be a hydraulic tappet failing,or the roller wheel on other end of rocker arm, bearing collapsing...
You would need rocker cover off to check.
Frag
Ford Technician
Re: top end noise??
Postby moffor » Fri Sep 26, 2008 12:30 am
I have a 2003 2.4 transit & have a loud tappet-type noise, increasing over he last few hundred miles. Took off the rocker cover & found the inlet rocker lifters variable. some seemed to have non-return valves working, others not working but the tappet noise seemed single! Some lifted freely others would only compress in a vice. Does anyone have experience of sticking non-return valves in transit 2.4 rockers?
ps its a 90-350
moffor
Re: top end noise??
Postby simonz » Wed Jul 04, 2012 4:16 pm
hi, doesnt seem that many people on here know much about the tappets/lifters.
ive got the same problem mate. 7 loose as you like and the rest solid.
havent tried putting them in a vice though.
i just want/need to know what a knackered rocker/lifter looks/ feels like as i must need to replace the ones that have exessive play. but how about the solid ones. have they siezed and are THEY the ones coursing the tapping??
first time ive seen any rockers on any vehicle
simonz
Re: top end noise??
Postby Cowboy711 » Wed Jul 04, 2012 7:54 pm
Hi all, having the same noise on my 2001 mk6 LWB too
This could be interesting.....
Btw I've not stripped the top off yet, as I need her on the road but I will be booking time to play soon!
Cowboy711
Re: top end noise??
Postby dieseldel » Wed Jul 04, 2012 8:46 pm
hi
if the engine has recentely been running then there should be no play in the hydraulic lifters, if there is then they are the ones that need replacing, simples
it was like that before i touched it !!
dieseldel
Re: top end noise??
Postby Cowboy711 » Fri Jul 06, 2012 9:26 am
So thats how to tell, thanks m8
Cowboy711
Re: top end noise??
Postby trannyfreak » Fri Apr 22, 2022 7:55 pm
I've got a very loud tapping on mine at the top end, soon as its warm it goes a little quiter, would this be the same problem?
trannyfreak
Re: top end noise??
Postby knobby1 » Sat Apr 23, 2022 2:28 am
trannyfreak wrote:I've got a very loud tapping on mine at the top end, soon as its warm it goes a little quiter, would this be the same problem?
Thread is near 14 years old now...so it may be better to start your own thread.
The last poster hasn't been back since 2013.
Re: top end noise??
Postby trannyfreak » Tue Apr 26, 2022 1:06 pm
OK thanks will do
trannyfreak
