Thermostat housing to block seal/water leaking ~ how/tips?
Postby thehangmen » Fri Sep 26, 2008 12:56 pm
Got water leaking out of the thermostat housing joint to the block, (presumably it's that, black plastic top/front of engine?).
Any recommendations on how to seal it up again, it looks like some white silicone type sealant is in there at the moment?
Mk5 2.5 diesel bananas.
thehangmen
Re: Thermostat housing to block seal/water leaking ~ how/tips?
Postby bazw » Fri Sep 26, 2008 3:49 pm
but a new gasket and change it
job done
350L Series 56 plate
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby Guy88 » Fri Sep 26, 2008 4:24 pm
bazw wrote:but a new gasket and change it
job done
plastic one has an oring between housing and head, 2 bolts out, housing off, clean up surfaces, new oring and back together
dont do the bolts too tight cus the housing will break
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby thehangmen » Mon Sep 29, 2008 12:15 pm
Thanks lads, can I assume no gunky stuff needed then?
thehangmen
Postby MinorMatt » Mon Sep 29, 2008 5:25 pm
Shouldnt be any need
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
