Transit connect rattle at 2000 revs every gear
Postby daveuknow » Wed Nov 05, 2008 8:52 pm
it is very annoing
in every gear there is like a rattle noise at 2000 revs
at it will do a little clonk when you 1st start the van also when you turn it off
also when your driving at low speeds like over speed humps. it will make the rattle
any help? also it does a clunking noise when i let out the clutch SOMETIMES.
this is my 1st ever question so be nice lol
daveuknow
Re: Transit connect rattle at 2000 revs every gear
Postby Turbo Tim » Wed Nov 05, 2008 10:01 pm
sounds like engine mount ?
Turbo Tim
Postby daveuknow » Wed Nov 05, 2008 10:05 pm
well it wont do it if the clutch is in or if you just rev it only if its in any gear and the clutch is out
daveuknow
Postby daveuknow » Wed Nov 05, 2008 10:06 pm
daveuknow
Postby Turbo Tim » Wed Nov 05, 2008 11:10 pm
it sounds like it is lash noise from gearbox,they seem to make the noise where the engine developes most of its torque, but also check to make sure no loose shields anywhere :)
Turbo Tim
Postby dcwuk » Wed Nov 05, 2008 11:30 pm
I had a similar rattle on my connect worried the shite out of me anyway quick look underneath and tightend the rear engine/gearbox mount nut a couple of turns rattle gone.
Its a circular mount just behind the sump. Try it you never know :)
'I have opinions of my own -- strong opinions -- but I don't always agree with them.'
-George Bush
dcwuk
Postby painter4 » Mon Nov 10, 2008 11:20 pm
i have the same noise as you describe its really annoying checked today and it kicks in at exactly 2000 revs :?:
painter4
Postby daveuknow » Fri Nov 14, 2008 6:43 pm
mine still aint fixed.
the van now has another fault to do with electrics. there bloody rubbish, you cant beat an old citroen berlingo
daveuknow
Postby bloomy » Fri Nov 14, 2008 8:36 pm
thrust bearing???
75 BHP BY DAY 375BHP BY NIGHT
bloomy
Postby daveuknow » Fri Nov 14, 2008 11:07 pm
well is there any way u can grease the bearing?
daveuknow
Postby Turbo Tim » Fri Nov 14, 2008 11:37 pm
no
Turbo Tim
Postby Sparkylarky » Tue Nov 18, 2008 1:22 pm
i had the same problem, luckily it was still under warranty as it was the gear box that was shot, all good untill the clutch went a month later due to a badly fitted rubber seal or something which was done when the gear box was fitted ... w*** haha
Sparkylarky
