side door wont open
side door wont open
Postby paul0li » Sat Mar 28, 2009 1:31 pm
Hi. I've got a '51 plate T260. The side door is double locked and wont open. Fuse is ok, I've disconnected the wires and connected locking mech directly to same wires to bypass the contact plate on the door, I've tried swapping red/white with red/black then double locking door to see if this opens it. I'm now stuck, reckon solenoid must be buggered but how do i open the door to remove it. please help....
paul0li
Re: side door wont open
Postby jizm » Sat Mar 28, 2009 1:39 pm
Can you not remove the ply and pull the cable by hand?
jizm
Postby paul0li » Sat Mar 28, 2009 1:45 pm
I've took door card off and pulled cable. I've stuck a big screwdriver in the little yellow hole and turned it but its double locked so wont release door. thanks for suggestion though. Next please...
paul0li
Postby Mike » Sat Mar 28, 2009 2:15 pm
It'll be dirt/corrosion on the three door contacts. My MK6 did it once and thankfully decided to open one day and I cleaned the contacts and kept them clean. Not sure how you'd go about opening it in your case though, maybe spray some wd40 type stuff at it?
Mike
Wind up merchant!
Postby paul0li » Sat Mar 28, 2009 2:52 pm
Thanks. I've disconnected the wires and linked out the door contacts but still no joy. Guess i'll have to get the grinder out and cut it open(if it stops raining long enough)
paul0li
Postby thunderider » Sat Mar 28, 2009 3:22 pm
try pushing the door with ur foot from the outside just under the handle and pressing the blue button on the fob,mine does this but its due to having pallets sliding and hitting the sidedoor.
I am the god of hell fire.....
thunderider
Postby bigjohnthomas » Sat Mar 28, 2009 5:22 pm
my 350 does it all the time pull the cable on the inside and get someone to bounce on the outside it always comes open eventually there is a knack to pulling the handle sharply and not denting the door it dont help having the bottom roller broken :roll:
bigjohnthomas
Postby paul0li » Sat Mar 28, 2009 6:30 pm
Tried bashing it, tried jumping on it.... no joy. its double locked so the latch wont release at all.... :x .....thanks for the ideas though...
paul0li
Postby winterheating » Sat Mar 28, 2009 9:02 pm
if you remove plug from 3 pin contact to the motor, of the motor side, think it is red black and green wires, you can swap or put a link wire in to swap 2 of the wires, of the top of me head think its red and green. when swapped press the fob to lock or unlock and it should open.
at least thats how i did my mates a couple of times when it deadlocked and wouldn't open, then a second hand motor/lock fitted and it was fine.
winterheating
Postby winterheating » Sat Mar 28, 2009 9:03 pm
and when the doors open you can check continuity of the 3 pin connection on door side and check power supply from van side, to rule themk out.
winterheating
Postby paul0li » Sun Mar 29, 2009 9:34 am
Thanks. tried swapping wires but still no joy... :(
paul0li
Postby Guy88 » Sun Mar 29, 2009 9:42 am
can you not take the motor out and operate it all by hand and remove the deadlock
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby paul0li » Sun Mar 29, 2009 9:59 am
I'd like to try that, but I cant get at it from the inside with the door locked.. Unless you know how :?:
paul0li
Postby jizm » Sun Mar 29, 2009 10:21 am
Maybe the door has dropped off the contacts, try levering the rear of the door up to make contact with the plate perhaps?
jizm
Postby winterheating » Sun Mar 29, 2009 10:48 am
sy
Guy88 wrote:can you not take the motor out and operate it all by hand and remove the deadlock
paul0li wrote:I'd like to try that, but I cant get at it from the inside with the door locked.. Unless you know how :?:
the motor part is the bottom of the lock where the 3 wires go to, can remove that from inside.
ive got one laid about somewhere i'll have a look see how easy it comes off.
winterheating
