alanwh wrote:
up the boost a bit too
please explain how to go about this
gardener68 wrote:so in theory i up the boost then re-increase the max fueling screw to produce the same small amount of black smoke on heavy throttle just like i did when i first converted from epic to 146 bosch.
where is the best or easiest place to connect up a take off for the boost guage![]()
thanks russ
alanwh wrote:Put in a Manual boost control, they're about £30. You'll need a good accurate boost guage as well though![]()
You can shorten the wastegate actuator rod a couple of mil, but it's not really recomended to move it from stock.
Don't do any adjustments without a boost guage fitted first![]()
Only adjust by small increments and don't go mad I've heard of crazy boosts but wouldn't go much above 1 bar. Think the 100ps is about .8 standard
gardener68 wrote:there is a large ish brass blanking plug on the top of manifold near the back.
should be able to drill and fix in a take of for gauge .
Andyg wrote:gardener68 wrote:there is a large ish brass blanking plug on the top of manifold near the back.
What's wrong with using your original MAP* port for the gauge, especially as it will no longer be using the MAP sensor
(*manifold absolute pressure sensor)
