mk6 diesel knocking sound
Postby hardgrafter » Tue May 12, 2009 8:18 pm
Hi gang been away a while!
just got hold of a 2003 swb t280 h/r 90k for a grand but it has a problem, on tickover it knocks but rev it and it quiets down, drives as it should and pulls well oil light goes out instantly on starting.
I suspected the dual mass but its not that sort of noise more a heavy diesel knock, vendor has produced a receipt for new injectors and a service, so i am at a loss any ideas lads???
hardgrafter
Re: mk6 diesel knocking sound
Postby fedup2 » Tue May 12, 2009 9:56 pm
Pump soloniod
Have a search.........
Launch x431 owner ;)
fedup2
Postby Dan T » Wed May 13, 2009 12:24 am
I wouldn't say timing solenoid as that usually has DTC's attatched and there would be a noticible reduction in power.
FWD or RWD :?: What ps engine :?:
Dan T
Postby fedup2 » Wed May 13, 2009 8:57 am
Dan T wrote:I wouldn't say timing solenoid as that usually has DTC's attatched and there would be a noticible reduction in power.
Quite right,usually 2 codes no light though. Reduced fueling code,which lowers the power and a pump timing code.
Did i not see an old thread with this where there was no loss of power?
I had the 2 codes,loss of power but no knock and ended up with a new pump.I was informed had it knocked on tick over it may well have been the solonoid but not without the knock.
I have to admit it doesnt quite fit with no loss of power.
Looks like some investigation has been done by previous owner who looks like they have bailed.Maybe they were informed of the biggy,the pump.
fedup2
Postby hardgrafter » Wed May 13, 2009 7:08 pm
Hey thanks, its a 75 fwd.
Is the solenoid an easy diy job?
hardgrafter
Postby fedup2 » Wed May 13, 2009 7:38 pm
Have you had it checked for codes?
Was the other work recent?
fedup2
Postby hardgrafter » Wed May 13, 2009 8:44 pm
fedup2 wrote:Have you had it checked for codes?
Dont have a reader, the work was done last month then van was left stood due to no MOT.
hardgrafter
Postby H17och » Tue May 26, 2009 11:33 pm
i also get this noise. dont get it when cold, or when hot. ONLY when i leave it to stand for anything between 10mins-2hours. before 10mins i guess its too hot and after 2 hours i guess its too cold !?!?
i did wonder about the oil!?
H17och
Postby hardgrafter » Sun May 31, 2009 8:03 pm
hardgrafter wrote:Hi gang been away a while!
SORTED, yes it was the pump timing solenoid, had to destroy the old one to get it out, pig of a job!
Runs great now. Thanks for the advice.
hardgrafter
Postby H17och » Tue Jun 02, 2009 3:55 pm
any more info? how much was it?
does my problem sound similar to yours?
cheers
H17och
Users browsing this forum: Google [Bot], vansit1
