trigger wrote:It would not aid coldstarting cos when the engine is cold there are no hot gases to introduce back into inlet
Jim Archer wrote:Indeed, but only after it's fired up mind
Jim
MinorMatt wrote:you keep believing that...
trust me there is very little heat produced just turning over... undo the egr and stick your finger down the hole while someone turns over a non firing Di engine...
trigger wrote:Believe me there is more power and smoother throttle response since doing the EGR mod, just shows how much use it was NOT
kinty wrote:i bet theres plenty on here with vauxhall cars and that have experienced problems with egr...totally different.
