alright peeps,
2 Part Post !
Firstly, ive got a replacement speedo cluster on the way with trip computer (my old one hasnt got one) - to get it working is there anything else required other than cluster swap and indicator stalk swap - im assuming ive got the wiring as there are 2 looms going to the back of the cluster - are there any extra relays et al required or is it not compatible full stop
secondly - ive got a spare mondeo stalk sitting here with adjustable intermittant wipe which looks pretty much identical to the original connect stalk (with the adjuster obviously) - is it possible to fit and make work ? - on the mondeo it was just a case of bunging on and putting a relay in the fusebox - is this possible on the connect ????
cheers
Brett
