Luke wrote:not sure if this is either true or allready on the forum but i cant find any info
but apparantly you can bypass the mk7 egr by removing a gear out of it so it stays shut but doesnt throw up the engine managment light
anyone tried it does it work
ake wrote:If you blank it it puts the light on, and if you unplug it it puts the light on, so i'm guessing if you take a gear out of it it will put the light on
belly wrote:Even your Egr looks cleanish Mike I'm quite surprised considering the trouble these things cause no one has designed a blanking kit that also adapts the signals for the ecu yet!
Luke wrote:nice pic mike i think its the middle gear he removed
Tdci_boy wrote:So now you have 1 apart, what was the fault, is it something the precision engineering company I use can have a look at & repair & maybe we could set up some kind of exchange scheme going
Tdci_boy wrote:Do you still have the unit or did they keep it
