slight knocking noise while the van was stationary
silvey87 wrote:Hi all got a mk7 transit 115 rwd its making a kocking noise and is idleing very rough untill its reved uo put the fault code reader on it said cylinder 4 balence injecter restricted so i thought i would unplug all the injecters 1 by 1 and see if it was no4 injecter faulty but all did the same thing when unplug just ran on 3 has anyone had the same problem im pretty sure its not a knock coming from the engine as in top end or bottom end because it stops when reving and idleing somtimes any ideas.
Users browsing this forum: Askeladd, Google Adsense [Bot]
