bleed transit connect clutch
Postby cdel2005 » Mon Feb 08, 2010 7:21 pm
could any one tell me how to bleed the clutch on a 53 reg connect step by step,as some of the gears are hard to engage
cheers
cdel2005
Re: bleed transit connect clutch
Postby redevo » Sun Feb 14, 2010 8:45 pm
i had this recently on mine, i was then unable to select first or reverse while stood still, the clutch was worn so replaced that and the hydrolic cylinder while gearbox was off.
Bleeding is easy, open bleed nipple, get someone to push pedal down and hold down while you close nipple, left pedal up, open nipple and repeat process untill happy no air is coming out. keep eye on fluid level though.
redevo
Postby cdel2005 » Sun Feb 14, 2010 11:28 pm
hi, thanks for the reply,im aware of the procedure, the problem i have is finding the bleed nipple? where the hell is it?
cdel2005
