EGR UNIT PROBLEMS ?
EGR UNIT PROBLEMS ?
Postby ChuckH » Wed Apr 11, 2007 7:05 am
My EGR unit has been replaced after a wait of 2 weeks to get the part (which sugests a shortage of parts ) It was done at 2200 miles two weeks ago Its now making the same grating noise as the old one !! So is this a common failure ????
Meant to say Its a Mk 7 2.2 TDCI 130 LX
ChuckH
EGR valve
Postby Daveyboy » Wed Apr 11, 2007 8:29 pm
Hi, yes it could be a problem, had mine replaced on my work van, but a RWD 350 115tdci at around 1600 miles, that was after numerous visits to the dealers who just kept wiping all the fault codes and recallibrating. Fingers crossed the engine management light hasn't come on since the replacement of the EGR valve.
Daveyboy
Postby Nighthawk » Wed Apr 11, 2007 8:33 pm
is the noise louder now than it was when the vehicle was new?
the EGR valve on 06----> transits is an electronic unit and it does a cleaning cycle when the ignition goes on and off to keep the actuator rod clear.
it sounds like a little man sawing for a couple of seconds :D
Transit.........Job done
Nighthawk
Postby ChuckH » Fri Apr 13, 2007 10:55 am
The last one got louder and louder This one is doing the same !! The van has only done 3500 miles !!! :?
ChuckH
Postby PMeyer » Wed Apr 25, 2007 10:27 pm
wow - just found this post. My 2000 w reg van is going in tomorrow to have EGR vavle replaced. I kept getting engine management light come on and then it would clear after the van had been running for a while, if i switched it off and then on again. Can't say I've heard any noises on startup like you describe though...
here's hoping it doesn't cost too much!
Love me, love my van.
PMeyer
Postby Nighthawk » Thu Apr 26, 2007 11:22 pm
Thats because your EGR valve is a vacuum controlled item, not an electronic type as fitted to current Transit
last time I looked, the EGR valve for the early duratorq 2.4 with the air temp switch was around 150 +vat and fitting
so a degree of arse stinging is coming your way
Nighthawk
Postby sus » Tue Aug 28, 2007 9:13 pm
Nighthawk wrote:last time I looked, the EGR valve for the early duratorq 2.4 with the air temp switch was around 150 +vat and fitting
surely it's covered on warrenty
sus
Postby MrMPuk » Tue Aug 28, 2007 9:21 pm
Not on a W reg.
Re: EGR UNIT PROBLEMS ?
Postby L33 DOB » Fri Mar 05, 2010 8:37 pm
My 2006 on a 56 plate in making theese scraping noises only when the engine is turned off. Like a wee man sawing under the bonet for a few seconds. The vans only done 12k. No managment light comes on and theres no fault on the dash computer thingymabob. Am i in for a nasty bill?
L33 DOB
Postby ake » Fri Mar 05, 2010 8:39 pm
No cos if you read the post properly the sawing noise is meant to happen, its the valve self cleaning :)
Postby L33 DOB » Fri Mar 05, 2010 8:58 pm
Its abit loud like
L33 DOB
Re:
Postby psv-hgv-flt » Sat Mar 06, 2010 11:30 am
PMeyer wrote:wow - just found this post. My 2000 w reg van is going in tomorrow to have EGR vavle replaced. I kept getting engine management light come on and then it would clear after the van had been running for a while, if i switched it off and then on again. Can't say I've heard any noises on startup like you describe though...
you be best to blank it off on the 2.5 di.
psv-hgv-flt
Re: Re:
Postby ake » Sat Mar 06, 2010 12:03 pm
That was posted in 2007, so they've probably fixed it by now :lol:
Re: Re:
Postby ChuckH » Sun Mar 07, 2010 8:32 pm
Your right Mate I posted this thread nearly 3 years ago My van now has just 27,000 miles on the clock And is on EGR Valve number 6 !!! Thats right 6 EGR Valves id 3 years and under 28k miles Ford still claim They dont have a problem with them Oh no ....................................................
ChuckH
Postby Tdci_boy » Sun Mar 07, 2010 9:51 pm
Don't have a problem with EGR valves, I'm on my 3rd, every single manufacturer that relies on EGR has problems with EGR valves, is it any wonder when you consider where they are operating, you would have thought someone would have cured the problem by now.
Transit Custom Limited H1 L2 DCIV, now converted to van by removing the seats etc so now twin side loading doors, fully kitted out with Sortimo racking, always loaded to capacity & averages 35mpg :D
Tdci_boy
GLX Posse
