Replacing the fibre camshaft gear on a V4
Postby welshrussell » Tue Jun 01, 2010 10:14 pm
Just picked up the cylinder heads from the engineers today - looking very nice, will post some photos soon :D
The heads have been skimmed, new exhaust seats fitted and some valve guides, now I just need to buy 4 new valves, 4 had worn too badly.
While I was there, the guy mentioned if now would be a good time to have a look at replacing the fibre camshaft centre piece behind the front cover.
This is what the engine looks like now, so obviously access is easy.
How easy/difficult would it be for me to whip off the front cover and replace this part - do I need any special tools and what should I be looking out for :?:
Do good things - and good things will happen to you!
welshrussell
Re: Replacing the fibre camshaft gear on a V4
Postby baconsdozen » Wed Jun 02, 2010 9:03 am
You can't get new ones anymore so it will be a question of fitting a secondhand one.That might be as bad or worse than the one that you take out.
The fibre ones tend not to wear as much as break off the teeth usually as a result of high revs on a cold engine.
baconsdozen
Postby Luke » Wed Jun 02, 2010 9:37 am
i wonder if we could get a drawing done and have some made out in steel or ally :?
mabe if there was enough interest to cover the cost :idea: i know if i ran a mk1 V4 i'd be interested in having one as a spare :D
Postby baconsdozen » Wed Jun 02, 2010 10:27 am
As far as I know you can still get the steel gears from someone like Burtons.They don't make them but buy them from someone (Quaife I think).They are over the £150 mark.
Alloy or steel wheels are expensive and noisy but do outlast the fibre jobbies.
baconsdozen
Postby welshrussell » Wed Jun 02, 2010 10:56 am
Sounds like I'm better off leaving well alone :?
I don't think there is anything wrong with it, I was just worried about finishing the rebuild and then someone pipes up....did you check the timing gear - doh :o
Got the Burton catalogue in front of me, on page 26, there is something called a steel cam gear for a V6 Essex, for £132.95 - is this the item I'm on about :?:
welshrussell
Postby baconsdozen » Wed Jun 02, 2010 12:19 pm
I might be wrong but I think the V6 wheels are balanced differently to the V4.If you really want a V4 one they are listed here.http://www.essexengines.com/ford%20essex%20v4%20engines.htm You'd be looking at around £200 for the kit.
baconsdozen
Postby AlanN » Wed Jun 02, 2010 12:24 pm
I thought about changing the one on my V6 cologne until I was quoted £163 +vat :shock:
Postby welshrussell » Wed Jun 02, 2010 12:29 pm
baconsdozen wrote:I might be wrong but I think the V6 wheels are balanced differently to the V4.If you really want a V4 one they are listed here.http://www.essexengines.com/ford%20essex%20v4%20engines.htm You'd be looking at around £200 for the kit.
Cheers for this Kevin, if I want to take it further, I'll give Burtons a phone for exact spec/price, etc.
welshrussell
Postby Southerner » Wed Jun 02, 2010 9:15 pm
Probably worth taking the cover off to look at it for piece of mind :?:
Don't know on a V4 but doubt it would be much hassle whilst you've the engine out?
Southerner
Postby welshrussell » Wed Jun 02, 2010 9:27 pm
Southerner wrote:Probably worth taking the cover off to look at it for piece of mind :?:
Was glancing through my Haynes and thought I saw reference to some sort of pulling/extractor device needed for the oil seal in the front cover.
So I'm guessing things could be a bit trickier than I first anticipated :roll:
Will have a proper read up on this before a spanner goes anywhere near the cover :lol:
welshrussell
Postby ian666 » Thu Jun 03, 2010 2:05 am
Hi, I got a steel gear from Burtons for £156. Easy to change, great except for the noise. At certain revs, it sounds like a siren.
Ian
ian666
Postby welshrussell » Thu Jun 03, 2010 8:48 am
ian666 wrote:Hi, I got a steel gear from Burtons for £156. Easy to change, great except for the noise. At certain revs, it sounds like a siren.
Ian
Thanks Ian.
My engine is still in the van (as per photo) but getting to the front cover is easy.
Was it as simple as just undoing the cover bolts to get at the timing gear :?:
And did you change yours over by just undoing bolts, etc - no need for pullers or special tools :?:
Cause if it is, then I'm seriously tempted to take off the cover to check the teeth on the current timing gear.
When I fitted an electronic ignition kit to the dizzy, that quietened the engine down a bit and made it a lot smoother.
How bothersome is the noise of the steel timing gear really :? :?:
Your thoughts on this would be appreciated - cheers :D
welshrussell
Postby ian666 » Fri Jun 04, 2010 11:25 pm
Hi, I managed the change without any ¨special¨ tools, and didn´t have a problem. I find the noise from the steel gears very obtrusive, a friend who lives over the road says he knows when the vans going out as he can hear it as soon as it starts. I´ll just have to fit a radio and turn it well up.
Cheers,
Ian
ian666
Postby welshrussell » Sat Jun 05, 2010 7:03 pm
Cheers Ian.
If my gear teeth still have a lot of life left in them, I'll leave well alone.
It's a real shame about the noise issue.
I'll just have to keep my eye out for a fibre one :roll:
I'll post pics of the teeth as soon as I finish painting and get around to removing the cover.
welshrussell
Postby madmark » Sat Jun 05, 2010 7:12 pm
i run a buton steel gear in my v4 :wink:
Return to Mk 1 & 2
