wilkyd53 wrote:Sure they will.
Bear in mind that 18" wheels so fitted will be 4% - 5% smaller than the norm, and running on tyres with a load rating of only 500Kg rather than the typical 690Kg. They'll be fine on a supermarket trolley
phillo wrote:Ah sorry.
I measured mine from the outside edge rim to the face that sits against the hub and it was 52mm so i assume if you went bigger on the offset the outer edge of the rim would be closer to the arch and the back edge of the rim would be further away from the strut.
