Mk 7 EGR Valve Removal
Postby barrytaylorryan » Thu Sep 09, 2010 10:21 pm
Been a while since i needed to pick up a spanner, so could someone help me out with how to remove and clean my EGR valve. I have a Mk 7 2.2 TDCI, it smokes slightly on pull away and under a hard right foot. Ford tell me "computer says no" and cant find a fault with the van, and after reading some of the posts on here to do with this "EGR Valve", I thought i would give it a clean myself and see if it makes a different. Thanks people.
barrytaylorryan
Re: Mk 7 EGR Valve Removal
Postby ake » Fri Sep 10, 2010 6:46 am
Its at the front of the engine, above the starter
Postby dangerousbryan » Fri Sep 10, 2010 10:10 am
It's held on with 2 10mm bolts and 2 8mm bolts. The 8mm ones are on to a flexi pipe. There is a steel gasket on both bits.
Bryan.
91 transit 120 sold
97 transit 150swb written off
95 transit 190 rolled over!
95 transit 190 sold
95 transit 80 with 150 springs. now scrapped
99 transit 190 longcube
dangerousbryan
Postby jacko1611 » Fri Sep 10, 2010 7:16 pm
clean the inlet too if its a high miler.
not another E G F*****G R!
jacko1611
Ford Technician
Postby barrytaylorryan » Fri Sep 10, 2010 8:56 pm
And is it as simple as only needing a 10 and 8mm spanner or socket to get it off or does anything else need to be removed to get it?
barrytaylorryan
Postby redvanman » Fri Sep 10, 2010 9:01 pm
sounds a doddle - I can't even see one of the nuts holding mine on :(
redvanman
Postby dangerousbryan » Sat Sep 11, 2010 7:47 pm
Rwd's are a pain to change. Fwd's are easy.
Bryan.
91 transit 120 sold
95 transit 190 sold
dangerousbryan
Postby barrytaylorryan » Sun Sep 12, 2010 8:45 am
Managed to take the EGR off yesterday and did my best to clean it out. It aint that hard to get off, even if its been while since you last touched an engine! Beacause its not that hard to take off, i took a template of both gaskets so i could make blanking plates and if i decide to do it, blank the valve off.
2 questions: do you blank the side that runs to MAF sensor or the other side of the valve or both? And what are the benifits of blanking it off?
Plus, will i get an engine management lit up on my dash?
barrytaylorryan
Postby ake » Sun Sep 12, 2010 5:56 pm
If its a MK7 you will get a fault light after a few miles
Postby jacko1611 » Sun Sep 12, 2010 9:02 pm
blank the side that goes into the valve if ure gonna do it. mil light will come on.
jacko1611
Ford Technician
Postby barrytaylorryan » Mon Sep 13, 2010 12:00 am
Is the gasket for the inlet manifold a steel or paper one?
barrytaylorryan
Postby Guy88 » Mon Sep 13, 2010 7:31 am
barrytaylorryan wrote:Is the gasket for the inlet manifold a steel or paper one?
the valve itself doesnt bolt to the inlet, it goes to a steel pipe behind the inlet, and yes they are both steel :D
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Users browsing this forum: Google Adsense [Bot], gt_addict
