starter motor removal
Postby piperdog » Thu Aug 03, 2006 6:18 pm
hello,can any one run by me the removal (and installation ) of a starter motor for a 51 reg ,rear wheel drive tranny ..big thanks :D
piperdog
Postby Nighthawk » Sat Aug 05, 2006 3:51 pm
    disconnect battery negertive terminal
    undo and remove the 10mm (spanner size) nut and disconnect the solenoid wire
    undo and remove the 13mm (spanner size) nut and disconnect the main starter lead and the alternator wiring
    undo and remove the 13mm (spanner size) bolt through the lower mounting point on the starter, this has an earth lead on it, push the lead to one side
    undo the top starter bolt (same as lower bolt) and remove the starter from the engine. The top bolt can't be removed from the starter with it in place, and it can't be fitted after you've put the motor back either so don't forget it!
rebuild is a reversal of the strip, should take no more than ½ hour even if your doing it on your back :)
Transit.........Job done
Nighthawk
Postby piperdog » Sat Aug 05, 2006 7:02 pm
it must be me ..but can you explain the last bit ..as its lost me :oops:
piperdog
Postby 100ps_drw_hicube » Sat Aug 05, 2006 7:08 pm
sounds like theres not enough clearance to completey take the bolt out so undo then lift starter out with it sitting the hole this is how i understand it !!! looking at the mk6 starter and its posistion i would say thats roughly what it is :? :roll:
100ps_drw_hicube
Transit Abuser!!
Postby rover » Sat Aug 05, 2006 7:46 pm
Dead right 100ps :D
Easy 10min job if you remember to sit the top bolt in the new starter before fitting it, unlike the first one i did when i got the bottom one in and then had to take the bugger off again cos I forgot :oops:
Rover.
rover
Postby Nighthawk » Sat Aug 05, 2006 10:11 pm
:lol:
Nighthawk
Postby rover » Sun Aug 06, 2006 4:57 pm
Its alright you laughing.....I was laying on my back at the side of the A52 in the pouring rain at the time :( to say I was swearing is an understatement :lol:
Laughing a little harder now :wink: :lol:
Rover.
rover
Postby Nighthawk » Sun Aug 06, 2006 5:57 pm
been there and done it......thats why i was laughing :lol:
Nighthawk
Postby rover » Sun Aug 06, 2006 6:17 pm
:D :D
Rover.
rover
Postby motorwise » Sun Aug 06, 2006 7:07 pm
rover wrote:Its alright you laughing.....I was laying on my back at the side of the A52 in the pouring rain at the time :( to say I was swearing is an understatement :lol:
Rover.
these things never happen in the dry workshop do they :D
http://www.motorwise.net
motorwise
Postby markja » Sun Aug 13, 2006 11:48 pm
i was in the army in three foot of snow years ago changing the propshaft on a land rover. :( so doing a transit starter in the rain's a doodle!! :twisted: ha, ha!
oh yes, the vicar wants a word about your language, rover :D
markja
Postby MICKA404 » Mon Aug 14, 2006 7:55 am
markja wrote:i was in the army in three foot of snow years ago changing the propshaft on a land rover. :( so doing a transit starter in the rain's a doodle!! :twisted: ha, ha!
REME fond memories of norway was it.
I ALWAYS PASS ON GOOD ADVICE. IT ISTHE ONLY THING TO DO WITH IT. IT IS NEVER ANY USE TO YOURSELF
MICKA404
Re: starter motor removal
Postby skipper081 » Sat Nov 12, 2011 6:31 pm
How do you get access to the electrical terminals because of the hoses?
skipper081
Postby APH » Sat Nov 12, 2011 7:03 pm
skipper081 wrote:How do you get access to the electrical terminals because of the hoses?
Use several extension bars together on the socket to allow you to use a ratchet nearer the front of the engine (almost touching radiator) thats how I do them, or remove two main bolts first, then push starter towards rear of van to give more clearance between hoses, however it won't go far as the loom is extremely short :wink:
Andy
(\__/)
(")_(")
this is bunny
APH
Postby skipper081 » Sat Nov 12, 2011 7:31 pm
THANKS ANDY...
skipper081
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot]
