Jetson2 wrote:Hi Folk’s , I am having problem with my 52 plate transit van [2002]the starter motor clicking ,the starter motor is brand new, after having the same problem with my old starter, I also had new clutch and flywheel fitted 2 year ago, took starter off van and it is clean ,put a new one on , but the fault is the same, turn the key and you just get the clicking, replaced earth straps to and from starter, the battery and alternator are new, fault still the same, if you connect it to a booster, it starts fine no clicking, but without the booster, it is back to clicking, when starter motor is clicking the central locking keeps opening and locking ,any help would be greatly appreciated.
v8rick wrote:Jetson2 wrote:Hi Folk’s , I am having problem with my 52 plate transit van [2002]the starter motor clicking ,the starter motor is brand new, after having the same problem with my old starter, I also had new clutch and flywheel fitted 2 year ago, took starter off van and it is clean ,put a new one on , but the fault is the same, turn the key and you just get the clicking, replaced earth straps to and from starter, the battery and alternator are new, fault still the same, if you connect it to a booster, it starts fine no clicking, but without the booster, it is back to clicking, when starter motor is clicking the central locking keeps opening and locking ,any help would be greatly appreciated.
that ruins all the above sugestions...
Jetson2 wrote:Thanks for the suggestion folk's , altough I said it is a new battery, it is about three month's old, and this clicking only started this week, so I can't see it being part of the problem, we have also replaced the battery earth strap.
Jetson2 wrote:Thanks for the suggestion folk's , altough I said it is a new battery, it is about three month's old, and it has been fully tested, this clicking only started this week, so I can't see it being part of the problem, we have also replaced the battery earth strap.
workhorse wrote:Jetson2 wrote:Thanks for the suggestion folk's , altough I said it is a new battery, it is about three month's old, and it has been fully tested, this clicking only started this week, so I can't see it being part of the problem, we have also replaced the battery earth strap.
When did you get the battery tested? because this week has been a very cold week for killing batterys and if it`s starting ok with a booster battery, I`d try to get hold of what you know for definate is a good battery around same output and put it on the van to double check?
mark b1977 wrote:Hi there did you find the problem as my van is doing the same thing.
cheers mark
Jetson2 wrote:mark b1977 wrote:Hi there did you find the problem as my van is doing the same thing.
cheers mark
Hi Mark, It turned out to be what most people said it was, I had a new battery fitted back in Febuary, because it was sluggish when starting, it turned out that they had fitted one for a petrol engine, they changed it for the right type, and problem solved hope this is of some help.
Users browsing this forum: Google [Bot], Google Adsense [Bot], metalworker0
