steering wheel removal
Postby stevepfd509 » Thu Jan 20, 2011 3:26 pm
hi guys can anyone here tell me what is needed to remove the air bag unit off the steering wheel need to get at the clocks :?
stevepfd509
Re: steering wheel removal
Postby p2thed » Thu Jan 20, 2011 6:27 pm
mk6 or mk7 :)
p2thed
Postby p2thed » Thu Jan 20, 2011 7:55 pm
mk6- held in with 2 8mm bolts if i remember rightly, remove both round plug to access.
mk7 - remove both top and bottom shroud, the airbag is held in with metal springs at rear (u'll probs need a mirror to see them). to remove push the springs down past there holding clips one at a time ( they can be a little stiff). if u have an old flat blade screw driver bend it into a right angle, works at treat :)
p2thed
Postby stephenferguson » Thu Jan 20, 2011 8:03 pm
on a mk 6 you can get the clocks out without removing the wheel.
2008, VW Transporter T5, T30, 6 Speed 130, Reflex Silver.
2006, 100 T280, MWB, Mid Roof, Moondust Silver. SOLD
Mk6-Mk7 Facelift Photos Here
stephenferguson
Postby jd-lee » Sun Jan 20, 2013 5:55 pm
Cheers mate. On my transit steering wheel the brown horn wire was earthed on steering. But the coax one isn't. Is this important do know? Did u have the same with ur cmax steering wheel
2007 Transit GLX 130 SWB - Now reprogrammed ECU to 140bhp and retuned to 170bhp by the man himself... vantuner - upgrade to six speed and has All the toys ;-)
Custom made front grill
jd-lee
Postby Rumble bee » Sun Jan 20, 2013 6:01 pm
I think I earthed it to the new wheel, not 100% though, try it without it first, you wouldn't to set the air bag off by accident :shock:
Rumble bee
Postby jd-lee » Sun Jan 20, 2013 8:02 pm
Lol
Yeah u need to earth it if u fit a cmax steering wheel. As I found out after putting it back together because without the earth horn works without ignition switch on. Turn on ignition... No horn.
Earth the brown wire to steering wheel and then horn works as it should.
Also just to let people know that if u have cruise control then cmax with cruise control works in transit.
Cheers for ur help rumble. To me ur almost worth ur weight in bronze :D :lol:
jd-lee
Postby Rumble bee » Sun Jan 20, 2013 9:05 pm
Good on ya, every day's a school day :lol:
Rumble bee
