greynwhitedog wrote:hi i,m a carpenter not very up on engines need to change the oil and filter on my 07 transit wheres the drain plug and wheres the filter also how often should i do this
CROSSFIREROB wrote:What ever Ford recomends is fine , but personaly i will be changing my oil every 5000 miles, as far as im concerned the engine oil is the life blood of the motor , if you fail to do anything dont fail to change your oil and filter,oil takes a severe hammering for thousands of miles , the oil particals are round when new , but become flattened as time goes by due to the extreem heat and pressure and hammering it gets ,and so the protection offered suffers , considering everything moving part lubricated and COOLED by the oil you would be crazy not to change it regularly ,if your a courier you will clock up miles fast , and will not want to change oil to often so go for a 8000 mile change , if your just plodding about local etc , go for a 5000 change , these are only my personal views, if you like Fords idea, let the van run 15000 MILES , the choice is yours, if you look aftre your motor it will look after you , my past trucks might have rusted and fallen to bits but the motors never failed , never yet anyway. .
El transito wrote:greynwhitedog wrote:hi i,m a carpenter not very up on engines need to change the oil and filter on my 07 transit wheres the drain plug and wheres the filter also how often should i do this
Assuming it's a diesel? you will need a 13mm ring spanner or socket and a 32mm socket, sump plug is 13 oil filter is 32. If its front wheel drive the filter is grill side of the sump, if its rear-wheel drive its between the sump and nearside engine mounting (Engine is just rotated 90' anti-clock) it's a "cartridge" type filter that fits inside the 32mm plastic cover that you will be removing.
A few tips, use the new "o" ring in the box, and do not over tighten the oil filter when replacing the plastic cover.
The "o" on the sump plug can stick to the sump, make sure you remove it from the sump and put it back on the sump plug before replacing it, you will "cross-thread" the plug if you don't.
The ford recomendation is 12500 miles or anually, whichever is earlier
Users browsing this forum: knobby1, metalworker0
