That last bit of your answer is what I wanted to hear.As I also have a Vuxhall Vectra 16 valve,and that is blanked,(with excellent results I might add).However,the inlet manifold,and the way that the whole induction system works,is very different to that of the DI engine,and that is what prompted me to ask in the first place,having read the earlier post on blanking.I will be blanking now,but didn't want to do it if there were any adverse effects.Thank's. FELIXX.pusd wrote:If the EGR is functioning correctly, you may see an improvement in consumption.
If the valve is not working right you probably will see an improvement in mpg.
Don't forget the improvement in driveability & low down performance along with keeping the engine (inc oil) cleaner for longer.
There really is no downsides!
Phil
Felixx wrote:That last bit of your answer is what I wanted to hear.As I also have a Vuxhall Vectra 16 valve,and that is blanked,(with excellent results I might add).However,the inlet manifold,and the way that the whole induction system works,is very different to that of the DI engine,and that is what prompted me to ask in the first place,having read the earlier post on blanking.I will be blanking now,but didn't want to do it if there were any adverse effects.Thank's. FELIXX.pusd wrote:If the EGR is functioning correctly, you may see an improvement in consumption.
Phil
alibabameister wrote:What effects does it have on a mk7 2.4, is it just as simple as removing it and blanking of manifold?
will I get any lights come on on dash or anything?
TIMO wrote:alibabameister wrote:What effects does it have on a mk7 2.4, is it just as simple as removing it and blanking of manifold?
YOU wont get the light to go out on dash
MrMPuk wrote:TIMO wrote:alibabameister wrote:What effects does it have on a mk7 2.4, is it just as simple as removing it and blanking of manifold?
Although that's not what he asked. He asked would it make the light come on?!
TIMO wrote:same thing .
MrMPuk wrote:TIMO wrote:same thing .
So you don't know then.
Users browsing this forum: Bing [Bot], Google [Bot], Google Adsense [Bot]
