Mk7 07 Rear disk replacement
Re: Mk7 07 Rear disk replacement
Postby taz666 » Wed Mar 30, 2011 7:14 pm
glad youve got it sorted :D
taz666
Ford Technician
Postby great2cyou2 » Tue Sep 06, 2011 11:21 pm
Wow - doing rear disc on an 08 Transit for the first time.
I really thought that Ford had obtained the ultimate in stupid designs with their front disc arrangement!
But hey - with a lot of perseverance and practice - they have managed to excel themselves and come up with an even more crazy design!!!!
Don't the f**kers even look at other manufacturers vehicles????
great2cyou2
Postby glenandemm » Wed Sep 07, 2011 2:43 pm
just reading this on the fwd reard discs sticking,im just wondering do the rwd rear discs have this much trouble as im gonna do mine soon on the bus!
glenandemm
Postby great2cyou2 » Wed Sep 07, 2011 5:04 pm
Ok,
Pressing the Disc off didn't do much except threaten to crack the disc.
Spoke to the local stealers and managed to talk to an actual mechanic.
He said ignore the press and warnings about hammers.
Chisels hammered between the back of the wheel stud and the disc. We had three thin chisels and tapped them in slowly and evenly and then went up a size once the disc moved slightly.
You would never think that about 8mm of interference could be so tight! Wondering if pressing the disc distorts it and tightens it further? No sign of anti seize anywhere. :(
great2cyou2
Postby taz666 » Wed Sep 07, 2011 6:56 pm
glenandemm wrote:just reading this on the fwd reard discs sticking,im just wondering do the rwd rear discs have this much trouble as im gonna do mine soon on the bus!
if youve read the thread properly you will see i have put how rears are done on rwd, not a nice job!!!!!!!!!!!!!!!!!!!!!!!!!
taz666
Ford Technician
Postby fedexsubcon » Sun Feb 12, 2012 10:19 pm
mk 7 RWD what is the size of the rear axle hub nut behind the halfshaft and what is the size of the torx bolts holding the discs to the hub? , also can you normally get the hub off without a puller? cheers chaps.
fedexsubcon
Postby Danbrad » Thu Oct 10, 2019 9:02 am
Hi all. Went to do my rear discs but the bearings are seized on. Any ideas how to remove them with basic tools or anybody close to Bridgend, South Wales I could lend or loan a hydraulic puller from.
Thanks in advance
Danbrad
Postby knobby1 » Thu Oct 10, 2019 10:07 am
Danbrad wrote:Hi all. Went to do my rear discs but the bearings are seized on. Any ideas how to remove them with basic tools or anybody close to Bridgend, South Wales I could lend or loan a hydraulic puller from.
Thanks in advance
Ummm....this thread is 7 1/2 years old so I doubt they're watching.
Do you have a FWD or RWD..?? I'm assuming FWD..?
Postby Danbrad » Thu Oct 10, 2019 10:24 am
Yes I did realise that but won't it get bumped up. Yes it is fwd
Thanks for the reply
Danbrad
Postby tilly » Wed Jan 15, 2020 3:01 pm
Actually.... I am watching my own thread. :lol:
Im assuming you got it sorted.
Mk7, FWD 110ps GLX in Silver 2007
tilly
Postby MattD » Thu Jan 16, 2020 5:50 pm
Mine were completely stuck. Tried everything but they wouldn't budge. In the end it was about £70 for a pair of hub bearings which I was more than happy with. Then made replacement of the discs very easy.
MattD
