Richard001 wrote:You will need the serial number off the back of the radio if it starts with an M then post it here viewtopic.php?f=40&t=59769&p=810355&hilit=radio+code#p810355 if it starts with a V then you need to speak to Ford
kawatriple wrote:Hi, yes i have pressed the phone button many times and the blue tooth on the i phone is turned off
gt_addict wrote:kawatriple wrote:Hi, yes i have pressed the phone button many times and the blue tooth on the i phone is turned off
I wasn't having a pop at your intelligence, it just hadn't been suggested I hope you get it sorted without too much aggravation
