Redlandrebel wrote:Sorry, I thought this was a Ford Transit Connect forum only. Yes, I have a 2010 Ford Transit Connect and the tire pressure is higher for the rear tires than the front. 39 Front, 49 rear. Obviously when you rotate the tires the sensors have to be reset. I think, because the van is a Turkish brand, the tire pressure monitors are different from the normal Ford TPMS. The manual that came with the van gives information on resetting but it is not working. Thanks again.
Redlandrebel wrote:Yes, Florida. The dealer keeps thinking it is a bad sensor, but I am not buying it. The van only has 15K miles. The directions in the manual does not work. Drive around for 2 minutes over 30 mph and then turn the van to off, back to on, without engine running, hit hazard three times and then the horn should beep. I have tried this about 5 times and it will not reset. There was something else about allowing air out slowly starting with the drivers side, but the instructions are vague. Thanks.
Kent Discos wrote:Redlandrebel wrote:Yes, Florida. The dealer keeps thinking it is a bad sensor, but I am not buying it. The van only has 15K miles. The directions in the manual does not work. Drive around for 2 minutes over 30 mph and then turn the van to off, back to on, without engine running, hit hazard three times and then the horn should beep. I have tried this about 5 times and it will not reset. There was something else about allowing air out slowly starting with the drivers side, but the instructions are vague. Thanks.
is someone pulling your leg or are you having a laugh... surely that's not the way to reset it!
