Do i blank off the egr valve or replace it? mk7
Postby ransom01 » Mon Oct 31, 2011 10:17 pm
Hi people, im running a mk7 transit mwb low roof 85 t280 , ive started getting a lumpy tick over and the EML on the dashboard which is reading code p1103 ( MAF sensor in range but higher then expected ).Is this due to a fault with the egr valve?, if so do i blank it off or should i replace it?, also what are the advantages/disadvantages of blanking it off?
Many questions, many thanks ;)
ransom01
Re: Do i blank off the egr valve or replace it??
Postby Guy88 » Mon Oct 31, 2011 10:38 pm
blanking it will put the EML on
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby ransom01 » Mon Oct 31, 2011 11:06 pm
Iv'e heard this might be a problem, is there no way around this that you know of?
Thanks ;)
ransom01
Re: Do i blank off the egr valve or replace it? mk7
Postby ake » Tue Nov 01, 2011 7:39 am
Replace the egr yourself, then get a Ford dealer to update the PCM on IDS and this will prevent the new egr from failing
Postby jacko1611 » Tue Nov 01, 2011 9:33 pm
Or use.the forum search button
not another E G F*****G R!
jacko1611
Ford Technician
Users browsing this forum: Google Adsense [Bot], M4NIK
