Won't turn over
Won't turn over
Postby happykfc » Mon Nov 07, 2011 2:29 am
Hi i'm back again
This time it's the second one that's the problem.
Basically the van will not turn over, any advice.
Bradley
happykfc
Re: Won't turn over
Postby ake » Mon Nov 07, 2011 7:36 am
What van? What engine? What age?
Re: Won't turn over
Postby Altransit » Mon Nov 07, 2011 10:38 am
All the help you had last time, and you just scrapped the van instead of following advice :roll:
Good luck :|
Re: Won't turn over
Postby happykfc » Mon Nov 07, 2011 11:00 am
Before we scrapped the other van, i manage to get it unlocked by following the advice from here and because it's a non-runner, we scrapped it after.
happykfc
Re: Won't turn over
Postby happykfc » Mon Nov 07, 2011 11:04 am
it's an 03 and a 2.0 Di Turbo Diesel (EGR) 55 kW (75 PS) 1998 cc
happykfc
Re: Won't turn over
Postby Altransit » Mon Nov 07, 2011 11:04 am
happykfc wrote:Before we scrapped the other van, i manage to get it unlocked by following the advice from here and because it's a non-runner, we scrapped it after.
Funnily enough, you never said that you had got it unlocked :?
Re: Won't turn over
Postby happykfc » Mon Nov 07, 2011 11:16 am
oh sorry about that. your right i should of told you i got it unlocked.
happykfc
Re: Won't turn over
Postby ake » Mon Nov 07, 2011 8:40 pm
Is battery charged? Have you tried some good quality jump leads? Whats immobiliser light doing?
Re: Won't turn over
Postby happykfc » Wed Nov 16, 2011 7:58 pm
ake wrote:Is battery charged? Have you tried some good quality jump leads? Whats immobiliser light doing?
today i had a look at the van and this is what happened.
i applied some power via jump leads and it gave it enough power to unlock it.
i left it to charge via the jump leads for 10 mins, and when i went back it had enough power to light the dash and for all the other thing (radio, lights, heater etc)
i went to turn it over and it just clicked. so i left it another half hour and tried again....once again clicking.
i did some research on fordtransit.org and it said to clean the terminals on the battery and the cable that connects to the battery.
after i had cleaned the battery i re-installed it and connected the cables...nothing, it had no life what so ever.
i got the jump leads back on and left it to charge for 1 hour, i went back and it didn't have any power in the van battery (except 2 volts)
the jumper cable were defiantly connected right.
i got out a volt-meter and put it on the car battery, it read 14v and then tried it on the van battery and it said 2v.
Is there a fuse gone or is the battery dead forever or what. i will be going back next wednesday. :?: :?: :?:
happykfc
Re: Won't turn over
Postby Altransit » Wed Nov 16, 2011 9:16 pm
The battery on the van is dead :(
Re: Won't turn over
Postby winterheating » Wed Nov 16, 2011 9:21 pm
If you take it off top the water up, tap water will do for topping up a little.
And give it a good charge trickle charge for 24,48 hours it may revive it.
Charging by the alt on a running engine isn't the same as trickle charging.
winterheating
Re: Won't turn over
Postby happykfc » Wed Nov 16, 2011 9:51 pm
winterheating wrote:If you take it off top the water up, tap water will do for topping up a little.
So the starter motor hasn't gone ka-put then (relating back to the clicking when turning the key
happykfc
Re: Won't turn over
Postby Altransit » Wed Nov 16, 2011 9:53 pm
It's clicking, because it doesn't have enough power to turn over :|
Re: Won't turn over
Postby happykfc » Wed Nov 16, 2011 9:58 pm
Altransit wrote:It's clicking, because it doesn't have enough power to turn over :|
ahhh, that makes sense, would you recommend a new battery or trickle charging? :?: :?:
happykfc
Re: Won't turn over
Postby Altransit » Wed Nov 16, 2011 10:04 pm
It's always worth a try to charge the battery before buying a new one :)
