Cleaning a map sensor?
Postby Martino » Mon Oct 24, 2011 8:01 pm
After reading a few threads ive heard that cleaning the map sensor on a van can help with mpg?...can anyone clarify this?
Does anyone know where its located on my MWB High roof mk6 2005 reg?, how easy is it to get to and how easy are they to clean....one post said it takes like 5 mins?....
I have a oil leak which seems to be coming from the manifold, this will be resulting in bad mpg right??...need to get it sorted!
Martino
Re: Cleaning a map sensor?
Postby angeleye » Mon Oct 24, 2011 8:33 pm
which manifold is leaking
ave mpg is 24/28 round town.....up to 38mpg on a run
compensation should be made for roof racks/trailors /weights
also keep tyres on higher pressures,check brakes dont bind,
most is down to driving style,
to help youself...blank egr....clean inlet manifold....consider a decat....and have a remap (having a lower power engine is not always good economy),always use correct oil
angeleye
Postby psv-hgv-flt » Mon Oct 24, 2011 9:48 pm
angeleye wrote:which manifold is leaking
+ tyre quailty/tracking/and balance.
psv-hgv-flt
Postby Beegly » Wed Nov 30, 2011 2:22 pm
is this where the map sensor is?
below the air box on a 2004 tdci 125 fwd.
i want to give it a clean but can`t locate it
Mondeo 130 TDCI - personal use
30t mobile crane - for work
2004 T280 125 TDCI, 183,000 miles. sold
'96 Citroën ax, 58ps. saved me over £1500 in diesel. SOLD, replaced with
2001 Citroen saxo 1.5 d
Beegly
Postby g-man » Wed Nov 30, 2011 3:31 pm
that will be the maf sensor,map will be just b4 the egr valve.........if its same as connects
g-man
Postby Beegly » Wed Nov 30, 2011 4:30 pm
this is my engine, from above i`ve looked and felt all the hoses but can`t find anything that may be the MAP sensor.
Do i need to be under the van looking at the engine facing the bulk head :?:
Forgive my ignorance :oops: :?
Beegly
Postby Guy88 » Wed Nov 30, 2011 6:08 pm
MAP is in the pipe out of the intercooler under the van
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby winterheating » Wed Nov 30, 2011 6:52 pm
It's in the intercooler itself drivers side.
winterheating
Postby Beegly » Wed Nov 30, 2011 7:20 pm
winterheating wrote:It's in the intercooler itself drivers side.
Thanks winter 8) , that`ll be why i couldn`t find it, how do get to it ? do you take the hoses off or is it fitted to the intercooler body (i can`t see out there now )
Beegly
Postby winterheating » Wed Nov 30, 2011 7:31 pm
2 small Torx screws in the end of intercooler drivers side.
winterheating
Users browsing this forum: wardus212
