Mk7 rwd front brake disc change
Postby blue estate » Fri Jan 13, 2012 7:25 pm
I am going to do my front discs tomorrow on my jumbo and i just want to clarify some thing :?
In the mk6 thread the brakes don't have Abs but my van has , is it the same process to change the discs on a mk7
blue estate
Re: Mk7 rwd front brake disc change
Postby Dan T » Fri Jan 13, 2012 10:00 pm
Yes
Dan T
Re: Mk7 rwd front brake disc change UPDATE
Postby blue estate » Sat Jan 14, 2012 5:51 pm
Update :!: i done my discs to day and on the mk7 the stub axle needs to come out because of the abs ring on the back as it's one cast complete
so you need a 36mm socket as well to undo hub nut
blue estate
Postby Dan T » Sun Jan 15, 2012 1:37 pm
blue estate wrote:Update :!: i done my discs to day and on the mk7 the stub axle needs to come out because of the abs ring on the back as it's one cast complete
Same as the Mk6 then like I said.
Dan T
Postby winterheating » Sun Jan 15, 2012 1:54 pm
But doesn't need to come out for none AbS.
winterheating
Users browsing this forum: Google [Bot], Telectric
