Problems with LDV convoy (Duratorque Transit Engine)
Postby olstonsurf » Fri Jan 20, 2012 10:53 am
Hi i hope someone can help me with my 2.5 ldv convoy.
I had it idleing for about 3 minutes and when i went to set off there was nothing coming from the accelerator , first i thought it was a cable but it didnt fel like it , so i managed to park it up, turned it off and back on and it worked again, so turned if off and on again but had trouble starting it till it finally fired up!!
This is one of many problems im having with this van , the full beam is constantly on when lights are on and when i try turning down theres a relay ticking by ECU (Which has just been replaced with the key reader after another problem )
One problem after another ! :x :x :x :x
olstonsurf
Re: Problems with LDV convoy (Duratorque Transit Engine)
Postby hortons » Fri Jan 20, 2012 12:16 pm
olstonsurf wrote:Hi i hope someone can help me with my 2.5 ldv convoy.
hi
your headlight problem is caused by a dirty connection on one of your headlight bulbs pull then off one at a time till the noise stops,you will find one of the connections is burnt,you may need to get a new plug [only a couple of quid]
regards Barry
hortons
Postby arrow » Fri Jan 20, 2012 2:44 pm
2.5 duratorq?
I don't think so !
arrow
Postby olstonsurf » Fri Jan 20, 2012 7:43 pm
hortons wrote:your headlight problem is caused by a dirty connection on one of your headlight bulbs pull then off one at a time till the noise stops,you will find one of the connections is burnt,you may need to get a new plug [only a couple of quid]
regards Barry
Cheers Ill have a go tomorow :D
olstonsurf
Postby Altransit » Fri Jan 20, 2012 8:07 pm
olstonsurf wrote:Cheers Ill have a go tomorow :D
Have a look to see which engine you have, pre 2002 build, it will be a 2.5TDi, after that it will be a 2.4 TDDi Duratorq :wink:
Postby Frag » Fri Jan 20, 2012 8:19 pm
In my very limited experience,Convoys seem to suffer from water ingress thru screen seal which causes electrical 'issues' to modules under dash etc.
Lack of accelerator response could be pedal itself,fairly common on the transit if same pedal assy.
Frag
Ford Technician
Postby olstonsurf » Sat Jan 21, 2012 11:06 am
Altransit wrote:Have a look to see which engine you have, pre 2002 build, it will be a 2.5TDi, after that it will be a 2.4 TDDi Duratorq
its a 2002 convoy so itll be the 2.4 tddi, ive had loads of bother with it to be honest.
olstonsurf
Postby olstonsurf » Sat Jan 21, 2012 11:08 am
Frag wrote:In my very limited experience,Convoys seem to suffer from water ingress thru screen seal which causes electrical 'issues' to modules under dash etc.
Ye i had to buy a new ECU due to the water corrosion on it
THanks
olstonsurf
