MK2 with a supercharged Mercedes diesel
Postby erling66 » Thu Jan 26, 2012 9:40 pm
Hi
Here are some info about my transit project. I hope it can be of interest for some even when it is not 100% Ford.
I saw a 1980 diesel transit for sale in the paper. I had been looking for a MK2 diesel for a few years, the only problem was that this car was 2000km away. The only photo in the ad was this:
But I would not miss the opportunity so I called the guy, said I bought it without seeing it and asked for his account and transfered money. The transit was mine :D
2 months later I went to the north of Norway to pick it up.
Shortest way back was trough Finland and Sweden. the trip up and down took me 6 days.
As you all know, the original diesel is not very fast so it had to go. My favorite engine is the Mercedes OM606 3L 6syl 24valve turbo 177hp diesel from w210 1997-2000 so I thought that the coolest van and the best engine would be a perfect match :) So I started the project
With a little cutting, the engine fit perfectly.
I will update the project when it progress.
erling66
Re: MK2 with a supercharged Mercedes diesel
Postby g-man » Thu Jan 26, 2012 9:46 pm
liking this 8) keep them pics coming
g-man
Postby oldskooler » Thu Jan 26, 2012 10:02 pm
class project, ill be watching this one closely, is that a fly by wire engine, ie,....throttle pedal etc or has it a injector pump and cable?
oldskooler
Postby Luke » Thu Jan 26, 2012 11:20 pm
8) 8) i certanly dont mind non ford engines :mrgreen: i've got a toyota engine in mine :lol:
look forward to some updates :D
Postby Greg L. » Sat Jan 28, 2012 9:09 am
The Transit looks great. Not much rust because of the salt/snow ?
Greg L.
Postby transitandy » Sat Jan 28, 2012 11:30 pm
Welcome to the site m8 :D you look like you know what your doing 8) 8) 8)
Postby erling66 » Sun Jan 29, 2012 1:49 pm
Here are some update.
The engine I am using is a Mercedes OM606. the engine are an update from the OM603 from 1985-1994 with a 24 valve head and an electronically controlled mechanical pump. The engine are by many considered the best diesel engine mercedes have made. I don't like the computer controlled pump(I like diesel engines that can run without electricity) but fortunately the older mechanical pump fit. But the problem with those pumps are that they can only deliver fuel for ca 175hp so I have mounted larger elements in the pump. Now it can deliver fuel enough for ca 450hp :D But to burn that much fuel you need air, lots of air, so this summer I am going to put on a supercharger.
It should take the engine to ca 250hp (with intercooler) later I have a plan to also fit a large turbo. That should bring the engine to 400+hp
I am putting on a 6 speed from a 2001 220cdi mercedes. It fits the engine but the axle is shorter so I had to shorten the housing
here is the new transmission mound, it is my first alu weld but it became quite strong(I can jump on it) so I hope it will hold.
I am working on the engine mounts now.
Thank you for welcoming me to this great site. There are lots of interesting info here. My car is made in Germany but i guess it is quite similar to the English Transit.
Yes the car has unusually little rust(we have a lot of that in Norway) I was very happy when I saw that since I bought it without seeing it :)
Maybe someone can help me to understand what all the codes on the plates mean? I am especially interested in Whats the name of the green color since I am planing to paint it in that color.
erling66
Postby transitandy » Sun Jan 29, 2012 4:12 pm
This is really great work m8y 8) 8) 8) 8)
Postby Luke » Sun Jan 29, 2012 6:26 pm
love it 8) 8)
the gearbox output flange looks the same as my toyota a340 box :D
Postby AndyG » Mon Jan 30, 2012 12:44 am
Love it 8)
Postby MattBlackMinibus » Mon Jan 30, 2012 9:47 am
Modern power in a Mk2 8) Perfect
Starting All Over Again
MattBlackMinibus
Postby Luke » Sun Mar 04, 2012 10:00 pm
any updates for us :?: 8)
Postby shovelheadrob » Sun Mar 04, 2012 11:15 pm
That's going to be an impressive van when it's finished, I've got a Roush supercharger on my truck (450bhp) viewtopic.php?f=23&t=1893&start=990 keep us posted.
Panther Black 2012 155ps 350 LWB Limited with extra toys
Leather, reversing camera, dual side doors, LED DRLs
shovelheadrob
Postby deankdx » Thu Mar 15, 2012 2:14 pm
wow, amazing i love it!
i was just thinking to myself the other day about whether the W123 300D mercedes engine and trans would be a good swap into my van..
great idea.
1980 Mk2 4.1 litre 5 speed manual, 2.77 or 2.92 falcon diff conversion, falcon front discs.
project thread herer viewtopic.php?f=27&t=24731&start=60
deankdx
Postby erling66 » Fri May 04, 2012 10:05 am
I finished the propeller shaft:) I used some different Mercedes parts and one part from the transit propeller shaft and welded them together.
Then I installed a hydraulic clutch using mostly Mercedes w124 parts. It is soft and nice so I think it will work fine.
erling66
