bonnet
Re: bonnet
Postby cruising comet » Sun Jan 03, 2010 11:06 pm
Did you get it open? :D
I know on occasions mine is tricky to open, if it goes in for work they cant usually open it, it's because they dont know how, there is a knack to opening it (with mine at least) the key has to be turned one direction to open, then in the oposite direction to release it, if the key is in the wrong way it wont open, taking it out & putting it back in the other way solves it, I found this a right pain but now I'm used to it it's a doddle!
Ford Transit Connect 1.8 T200 SWB (2003)
cruising comet
Re: bonnet
Postby winterheating » Sun Jan 03, 2010 11:22 pm
cruising comet wrote:Did you get it open? :D
thats how there supposed to be, should have arrows on somewhere to show people, like on mondeos and focus's.
winterheating
Re: bonnet
Postby mylo rooney » Mon Jan 04, 2010 10:14 am
going getting key cut this morning will let you know if it works or no :?:
mylo rooney
Re: bonnet
Postby mylo rooney » Mon Jan 04, 2010 12:25 pm
bingo ,got key cut without the fob £10.3 pence,opened first time thanks for your replies
mylo rooney
Re: bonnet
Postby winterheating » Mon Jan 04, 2010 2:49 pm
9 out of 10 its just the key :wink:
winterheating
Re: bonnet
Postby mylo rooney » Mon Jan 04, 2010 3:45 pm
bingo got new key cut £10.3p,without the fob and opened my bonnet thanks for replies lads :D :D
mylo rooney
Re: bonnet
Postby Lefty64 » Mon Jan 04, 2010 7:07 pm
I've been following this thread with interest, and am more than a bit puzzled by the outcome.
According to the Ford blurb these keys are supposed to have an inbuilt rolling transponder code (chip) facility, so are a teeny bit 'intelligent'. Otherwise what's all this business about reprogramming them from the ignition/immobiliser circuit by rotating the key nine or so times in the ignition when you obtain an alien key?
Have I got this wrong? Is it actually the remote key fob that's got the chip in it? If so, do the fob and key talk to each other each time you try to start up? What's actually going on here? :oops: :oops:
If your man just got a duplicate key cut by his local locksmith which worked, then it sounds like the Connect bonnet lock doesn't need a properly chipped key at all. If so, it's purely mechanical. It can be opened with any (Connect-type) key, or even maybe any other Ford key for all we know
I had a SWB 220 Hallmark before my present LWB 230, which came with a duplicate key & fob as part of the deal. I couldn't see any physical difference at all between the end of the key for either van, and told the dealer I wanted a freebie spare set for my new van. I got the same duplicate key set back in under a minute reprogrammed to my 230. If I'd tried this manoeuvre meself I'd have made a tit of it.
So what did they do or is all this black magic? Anybody got an explanation? :?: :?: :roll:
2007 T230LX LWB (110PS) with aircon.
Vans are designed for people with imagination. Cars are so limiting ... what can you do with them?
Lefty64
Re: bonnet
Postby belly » Mon Jan 04, 2010 7:22 pm
the locks are purely mechanical ! so if its just a normal key it could open the bonnet and doors but not start the van! as for any key opening it unfortunately there are other tools that do this ! :? also as far as im aware the key doesn't talk to the fob the fob is for the central locking and it's the key itself that has the transponder in for the immobiliser,when i got a spare fob as the old one snapped of the key ring the bloke at ford did the cycle thingy for me :)
belly
Kaiser Chief
Re: bonnet
Postby MrMPuk » Mon Jan 04, 2010 7:26 pm
wilkyd53 wrote:I've been following this thread with interest, and am more than a bit puzzled by the outcome.
The immobiliser\chip part of the key is only required for starting the vehicle.
Re: bonnet
Postby belly » Mon Jan 04, 2010 7:30 pm
Beat me to my edit :lol: can't type or punctuate for love nor money :(
belly
Kaiser Chief
Re: bonnet
Postby jonesyc » Fri Mar 30, 2012 11:10 pm
Hi i have had the same problem trying to open the bonnet of my connect, turned the key to the left but bonnet will not release the nice RAC man told me to make shaw the key is fully push home into the key hole then turn left then right ,this did trick.His says the rubber weather seal at opening to the key hole some times prevents the key from fully locating so just push the key in harder and turn.
jonesyc
Re: bonnet
Postby Kent Discos » Sat Mar 31, 2012 9:51 am
you always have to turn the key one way to release the catch and the other to allow lifting by the way :)
Jack Wilson | 2017 Transit Custom 290 130PS from Absolute Vans
Kent Media Group - http://www.kentmediagroup.co.uk | Kent Discos - http://www.kentdiscos.me.uk
Kent Discos
