Hi all
I have a 190 MK5 hi cube 2.5 deisel. The axle is off a mini bus with a taller ratio. The question is are the rear brake calipers interchangeable between the 20.6 bore and the 25.4 bore. I ask as I need new calipers and the mk 5 originally had 25.4 but the calipers on at the moment are 20.6. I have the original calipers off the old axle and they are in good nick and was hoping to just swaqp them over.
Apreciate the wisdom of those that have gone before
Justice
