TDCi in tank fuel pump question.
Postby Pan24v » Thu May 10, 2012 7:07 pm
When you turn the ignition to start, should you hear this pump priming?
Any info on this would be great help.
Many thanks. :)
Pan24v
Re: TDCi in tank fuel pump question.
Postby taz666 » Thu May 10, 2012 7:11 pm
no connect diesel has a fuel pump in the tank, only petrols have them :D
taz666
Ford Technician
Postby Pan24v » Thu May 10, 2012 9:24 pm
taz666 wrote:no connect diesel has a fuel pump in the tank, only petrols have them :D
Thats strange, Ford seem to think that I do have a pump built into the sender unit? :?
Quote from Ford Parts UK "Transit Connect 2002 (+)"GB" 80 Series 1.8L Duratorq TDCI (90PS) Extended Van RHD
Immersed Electric Fuel Pump & Sender Assy
Finis code is 1354274?
The reason why i'm asking is i'd like to check that its working but don't fancy dropping the tank unless i have to.
Thanks for your reply. :)
Pan24v
Postby winterheating » Fri May 11, 2012 12:20 am
Ford parts uk :?: :?: :?: :?: :?: :?
winterheating
Postby Pan24v » Fri May 11, 2012 7:10 am
winterheating wrote:Ford parts uk :?: :?: :?: :?: :?: :?
All I do is fill in a parts request form on http://www.fordpartsuk.com/ thats how I obtain my part numbers if I don't know them and find out if its too expensive to buy. A very useful site recommended by my local main dealer a few years ago as they couldn't get a particular part for me and Ford Parts UK came up trumps! :wink:
Pan24v
Postby taz666 » Fri May 11, 2012 8:46 pm
well all i can say is i wish my 09 tdci connect had a pump in the fuel tank, it would make changing the fuel filter so much easier
taz666
Ford Technician
Postby blue estate » Fri May 11, 2012 8:51 pm
Aka Edwards ford Salisbury (foray motor group ) main dealer / or national clearance on ebay or English ford poole Andover ford andover
blue estate
