newbie needing advice.
Postby former1742 » Wed Jun 20, 2012 7:26 pm
Hi there,
I've just brought a 2006 mk6 90 t350 nd I was wondering wat I should do to protect it for the long run. I'm thinking of wax oiling the bottom nd wheel arches. I've noticed small patch of rust producing just below the side loading door nd I was also wondering what to do to catch the problem early.
Cheers for any replies.
2016 Transit 125ps v363 L3 H2
2006 Transit 90ps t350 lwb medium roof
2008 Fiat Ducato Multijet 100ps L2 H1 with a 2.2 transit engine as standard
former1742
Re: newbie needing advice.
Postby Punto443 » Wed Jun 20, 2012 8:49 pm
Wax oil and undersell, but make sure you give it a good scrape back on the loose bits first. There's a few threads on what's best for underselling on here, but make sure you keep the drainage holes clear! My side door sill rusted to pieces very quickly from inside out because drain holes were blocked :(
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby former1742 » Wed Jun 20, 2012 10:05 pm
Ah rite yh that sounds good mate, I must admit I wouldn't of thought of that to be honest. Thanks for the advice. Are there many drainage holes or hidden ones to look out for?
former1742
Postby Punto443 » Wed Jun 20, 2012 10:19 pm
Mostly just along the sills and side door track, and under the front door steps
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby former1742 » Wed Jun 20, 2012 10:46 pm
Oki doki do I apply wax oil first then underseal? Also does it take a long time to dry?
former1742
Postby Punto443 » Thu Jun 21, 2012 1:10 am
Way oil in the internal bits, chassis rails etc. underseal on external areas. Usually quick drying but dependant on temp etc
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
